Engine Code: P1494 - JeepForum.com
post #1 of 49 Old 04-12-2008, 03:57 AM Thread Starter
00xj54
00xj54's Avatar
Engine Code: P1494
I got light and ran the code. Came up with this.
P1494
Definition
Evap leak detection pump pressure switch condition
Explanation
ECM detected the leak detection pump swith did change after solenoid was energized
Probable Cause
1.-Leak detection pump defective
2.-Open or shorted circuit condition
3. Solenoid defective
Soooo what does it all mean. Any help would be.. uhh... helpful.
[I]00' XJ Sport. 4.0 I6.
[B]|15" Canyon Crawlers | 30x9.5 Bridgestone Dueler A/T Revos | [Lifted (2" Teraflex Spacers | 2.5" RE AAL | Edlebrocks IAS)| K&N Homebrew Intake | Flow Master 70 |Clear Corners/Side Markers| Class III Hidden Hitch | C4x4 Fronts Tow Hooks | JKS Discos | Surco Safari Rack | Hella 500s |
00xj54 is offline
post #2 of 49 Old 04-12-2008, 07:45 AM
SilverXJ
The P1494 code is in fact the leak detection pump. Its the little round thing near a green valve cover on the passenger fire wall. The FSM doesn't give me any more information on testing other than to replace it.
SilverXJ is offline
post #3 of 49 Old 04-12-2008, 05:12 PM Thread Starter
00xj54
00xj54's Avatar
Back to the top
00xj54 is offline
post #4 of 49 Old 04-12-2008, 05:42 PM
SilverXJ
Have any friends with a 00+ Jeep? Could try swapping out the pump, clearing the code and see if it comes up again.
SilverXJ is offline
post #5 of 49 Old 04-13-2008, 02:48 AM Thread Starter
00xj54
00xj54's Avatar
I guess I could do that. Thanks.
Now I just need to find someone.
00xj54 is offline
post #6 of 49 Old 04-13-2008, 10:22 AM
Walter Crovo
I have a spare pump, probably not your problem. ck the evap lines on the driverside firewall where they change direction and go toward the tank, the 90 degree connecting hoses crack and leak.
93 5 speed over 160k
99 5 speed over 85K
01 auto over 70k
99 auto over 90k
Walter Crovo is offline
post #7 of 49 Old 04-13-2008, 03:02 PM
louisd11
I just removed the codes and haven't seen it since.
2000 XJ Jeep Cherokee Sport 4.0 HO I6
NP231, AW4
-Dana 30 Front w/ 3.55 Gears
-Chrysler 8.25 Rear w/ 3.55 Gears
Horn Blasters 4 Horn set, Dynomax cat back sys., K&N FIPK, Fire Ext., Warrior Bumper (HERCULINEDw/ D-Ring Tabs)
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
louisd11 is offline
post #8 of 49 Old 04-13-2008, 05:40 PM
cajunbull61
I just dealt with this exact problem with on my 2001. It popped up and I erased the codes, stayed off for a short time then came back. I did some research on the internet and found a lot of info. One thing to check for is a vacuum leak. Trace the small vac line from the evap solenoid on the passenger side firewall to the intake manifold. There is a rubber connector that hooks up to a fitting on the intake. Mine was soft and starting to deteriorate and was off of the fitting. I think mine popped off when I was starting my Jeep and it "sneezed". I let the key go just before the Jeep started and it made a sound like a sneeze or cough. Anyway, I replaced the connector and reset the computer and haven't had anymore issues since. My advice is to check all your vac lines before buying any parts.
cajunbull61 is offline
post #9 of 49 Old 06-14-2008, 01:08 PM
djeep1994
i just received this same code this week and I also realized that i am leaking antifreeze out of my freeze plugs. Would this just be detecting the leaking antifreeze. Or is this just another problem that i am going to have to deal with. Thanks guys
THE HARDER YOU TRAIN, THE HARDER IT IS TO SURRENDER
djeep1994 is offline
post #10 of 49 Old 06-14-2008, 08:11 PM
JeepJinx
---deleted---
JeepJinx is offline
post #11 of 49 Old 08-11-2008, 03:40 PM
jimraupp
2001 FSJ Cherokee
cajunbull61 pegged it
I also did a lot of looking on the internet, and tried to figure out what could possible be under the airbox. Finally saw the emission label clearly, the LDP is under the passenger side hood hinge. Traced the lines back, I don't know HOW we missed the vacuum line hanging off near the intake manifold !!! The 90 degree elbow is also soft, I'll be replacing that.
jimraupp is offline
post #12 of 49 Old 03-03-2010, 01:11 PM
brian0128
Glad I found this thread. I had the same code on a 99 Cherokee and found the LDP and traced the vacuum lines back and found a 90 degree elbow that had come off the intake manifold. I'm going to go and pick one up tonight to replace it. How can I clear then engine code? I had it read by Auto Zone.
brian0128 is offline
post #13 of 49 Old 11-16-2010, 07:25 PM
barrys
Mine "sneezed" also, I quickly found the 90 degree elbow on the intake manifold that was off. The light went off and hopefully will stay off. The elbow is soft so I will look into getting a new one.
barrys is online now
post #14 of 49 Old 04-10-2011, 12:51 PM
1992 renagade
Thanks for the info I enjoy a easy fix. I too found the vacuum
elbow off at the intake manifold a quick trip to Pep Boys for a 5/32 x 5/32
vac. connector and i'm back in business!
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #15 of 49 Old 06-04-2011, 08:10 PM
RyMac
P1494
Man am I glad that I found this thread.... 90 vac line, dry rotted and popped off just like the rest of them. Put on a new 90, cleared the code and good to go. Thanks
RyMac is offline
code p1494 question jersey_jim XJ Cherokee Technical Forum 3 11-16-2009 10:40 PM
2000 jeep troubleshhoting code P1494 info ? lonewolf5347 XJ Cherokee Technical Forum 1 09-29-2009 02:55 PM
p1494 code mikemm XJ Cherokee Technical Forum 2 06-29-2009 04:51 PM
Check Engine Code P1494 typer1122 XJ Cherokee Technical Forum 1 06-23-2009 03:12 PM
Check engine light on, Code is P1494 ??? Elohim1 XJ Cherokee Technical Forum 2 01-09-2005 04:23 PM
