Engine Block Coolant Drain Plug - JeepForum.com
post #1 of 12 Old 08-11-2002, 09:25 AM Thread Starter
FlyinJeep
I'm draining & flushing the cooling system on my 96 cherokee (4.0L 6). There's is a block drain plug on the left side of the engine that the book says needs to come out to get all the the coolant out of the engine. Anybody know what size the plug is? I can barely see the darn thing much less tell what size wrench, ratchet, whatever it will take to get it out. Do you guys actually take it out? Does it matter? I'm used to doing alot of my own maint. but I am new to the Jeep world. Just got my Cherokee about a month ago. Thanks for any help you can give me.
Tony
FlyinJeep is offline
post #2 of 12 Old 08-11-2002, 12:45 PM
Linux Nuke
1994 XJ Cherokee
Don't even think about removing it unless you have the manifolds off for access.
Otherwise, you can just about see it with something like a dentist's mirror, and just about reach it with your hand, both from below.
It has a 5/16" square female socket (ie not a standard socket drive size like 1/2" or 3/8").
I once made an adaptor to try to remove it, but in the restricted space I just could not exert enough force to move it.
It is in the owner's handbook as a routine job as if any owner could do it, but goodness knows why.
Don't worry. Flush the engine by disconnecting the radiator hoses and then sticking a garden hose pipe into a heater hose connection and blasting through.
Linux Nuke is offline
post #3 of 12 Old 08-11-2002, 01:44 PM Thread Starter
FlyinJeep
Thanks for the reply Linux,
Just came in from the garage to see if anybody had an answer. That's what really put me off, was the fact it talks about in in the owners mannual and the repair book that I have. They make it sound like you can just reach in there and take it out, no worries at all! The only way that I could even SEE the thing was with a mirror. And the other thing that was confusing was that a 3/8 rachet was too big and a 1/4 was too small. It makes since now that you say it is a 5/16. What I did was exactly what you suggested. I flushed it through the heater hose with the bottom radiator hose removed (I was replacing all the hoses also).
Seems like great minds think alike, huh?
Thanks again for your thoughts and help.
BTW, I come to England a few times a year with my job, always have a blast. Usually come to the Cambridge area, they have some great pubs! Cheers.
Tony
post #4 of 12 Old 08-11-2002, 03:59 PM
Flanz
This is just great timing. I was about to flush my roommates system and I came in here and this was the first post. Now I won't even try to look for that bolt. You have both been a great help. Thanks
'88 XJ 4.0L Rusty's cat back exhaust with Flowmaster
Flanz is offline
post #5 of 12 Old 08-23-2013, 05:50 PM
silver7even
The correct tool Item#94961
Harbor Frieght
silver7even is offline
post #6 of 12 Old 08-24-2013, 02:15 PM
Bobplymouth
1997 XJ Cherokee
I have been flushing my 97 and 98 often this summer.
I remove the drain plug on the passenger side of the radiator,
by removing the headlight cover, and signal light.
Bobplymouth is offline
post #7 of 12 Old 01-07-2014, 12:44 AM
AZSobo
Location: Somewhere in the desert west of New Mexico and east of California.
Harbor Frieght
Can you get in there with that on a ratchet or breaker bar?
2001 Jeep Wrangler Sport, 4.0L, 30x9.5 15 Tires on Alum. Rims, Tomken Bumpers front and rear - Everything else Stock
AZSobo is offline
post #8 of 12 Old 01-07-2014, 11:14 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Don't bother with the block drain plug, or the radiator drain. One is a pain to reach, and the other is too fragile. Just remove the lower radiator hose. Collect and correctly dispose of the drained coolant.
CJ7-Tim is offline
post #9 of 12 Old 01-07-2014, 02:58 PM
AZSobo
I haven't crawled under to look yet (TJ not XJ) but I need to switch coolant from an OAT to a HOAT and was really hoping to cut down on the number of times I have to flush with water. Disposing of all that water is a PIA - where I live no one wants it, the chemical waste dump that does take it charges per gal.
AZSobo is offline
post #10 of 12 Old 01-07-2014, 04:15 PM
CJ7-Tim
CJ7-Tim's Avatar
If you have city water and sewage treatment, you can pour it down the drain.
CJ7-Tim is offline
post #11 of 12 Old 01-07-2014, 05:59 PM
BlueRidgeMark
1994 XJ Cherokee
BlueRidgeMark is offline
post #12 of 12 Old 01-07-2014, 06:02 PM
BlueRidgeMark
1994 XJ Cherokee
If you have city water and sewage, you can pour it down the drain.
HERESY!
Or... maybe not.
http://www.imcool.com/articles/antif...r_Disposal.php
(Posted for the benefit of anyone who might get bent out of shape at Tim's suggestion.)
That's CITY sewage, folks. If there's a municipal sewage treatment plant at the end of your drain, fine. (Though it would not surprise me if it's illegal in some jurisdictions.)
Otherwise, it's very much NOT fine.
Where is the engine block coolant drain plug??? ki1022 XJ Cherokee Technical Forum 22 12-31-2015 11:38 AM
Engine Coolant Drain plug...where? RogueXJ XJ Cherokee Technical Forum 4 02-18-2011 11:56 AM
Where is the block coolant drain plug? themow XJ Cherokee Technical Forum 4 11-25-2008 04:10 PM
Do the 4.0L engine have a plug to drain coolant? fortcollinsram XJ Cherokee Technical Forum 2 05-20-2005 07:51 PM
'88 Diff Plug/Block Coolant Drain Plug sroodtuo74 XJ Cherokee Technical Forum 2 09-26-2004 03:49 PM
