Quantcast Engine from 01 Grand work in 00 Cherokee? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Engine from 01 Grand work in 00 Cherokee?
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 02-07-2008, 05:56 PM   #1
95cherokee33s
I bought an engine from a 2001 Grand cherokee thinking they were the same. The oil filter is in a slightly different location, and there is no place for the oil pressure sending unit. Is there an adapter I need to buy or is it just a different block? Thanks
95cherokee33s is offline   Reply With Quote
Old 02-07-2008, 06:12 PM   #2
Me007gold
you can make anything work with enough fab work
Me007gold is offline   Reply With Quote
Old 02-07-2008, 08:25 PM   #3
collkid
sounds like its not going to be a direct bolt it... did those come with the normal AW4?
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline   Reply With Quote
Old 02-08-2008, 11:49 AM   #4
nascartony05
1994 XJ Cherokee
Little different scenario but basically the same type of thing. I just got done taking a 4.0 from an 87 XJ and put it in a 94 XJ. I had to take pretty much everything off the 94 block and put on the 87 but it seems to be working fine so far.
nascartony05 is offline   Reply With Quote
Glock Forum
