Eng. Code P0118... - JeepForum.com
post #1 of 2 Old 11-30-2006, 01:24 PM Thread Starter
xb12r
xb12r's Avatar
Eng. Code P0118...
My XJ (99 4.0L 95,000mi) started running really crappy the past 3 three days (Dieing and taking 5 or 6 long cranks to start after dieing, studdering on accel, and high idle) and my check engine light came on, When i ran the codes i get 'P0118 Engine coolant temp circuit high input'... Besides what it says what is it talking about? How would i check it? and Would that make the jeep stall, studder and then sometimes die? I just receltly found a wired harness that was burned thru about 6 wires but i repaired them, the right way, Also i just recently replaced my Cap, Rotor, Plugs and Wires... Anyone have this problem and know a good solution?
1999 XJ 3.5 RE Super Ride, 31x10.5 Re-treads RE heavy duty track bar, RE Shackles, TBM...
Tire size, its not how big they are, its where you can make them take you...
xb12r is offline
post #2 of 2 Old 11-30-2006, 01:26 PM
anony91xj
There's a probem with the coolant temp sensor or associated circuit. Yes, it would cause the symptoms you're describing. The sensor is located in the thermostat housing. Visually inspect the wires, follow them back, be sure that they don't run through the bundle you repaired. If the wiring looks OK, replace the sensor.
I believe you can turn the key on (engine off), disconnect the sensor, and use a DVOM to probe the terminals on the sensor connector. You should have 5 volts there. If you have more tha 6 volts, there's a short somewhere.
1998 VW GTI 2.0
anony91xj is offline
Code P0138 high voltage code, Bank 1 sensor 2? crmaverick89 XJ Cherokee Technical Forum 21 08-07-2017 04:31 PM
OBDII Code P0118 marxman XJ Cherokee Technical Forum 14 06-06-2017 06:26 PM
2000 xj P0118 check code Barnfind XJ Cherokee Technical Forum 1 03-20-2009 05:28 AM
P0118 Dtc kadetklapp XJ Cherokee Technical Forum 0 10-11-2008 09:49 AM
Anyone know how to fix a code 41? MudColoredXJ XJ Cherokee Technical Forum 3 03-01-2005 09:12 AM
