Emission issues - JeepForum.com
post #1 of 5 Old 06-04-2011, 07:52 AM Thread Starter
cmabolt
Emission issues
Hello all, I have been having issues with two codes. 4055, 4032. I have decided to deal with them one at a time. I have replaced the converted and 02 sensor on the rear manifold, but 4032 code persists. Any ideas as to what it could be now.
As for the 4055, I plan on getting a smoke test and go from there.
Urggg. Any help would be much appreciated as I am trying to get through emissions test.
cmabolt is offline
post #2 of 5 Old 06-04-2011, 09:08 AM
Saudade
1988 XJ Cherokee
How did you pull those codes? Those are not normal OBD-II codes.
Saudade is offline
post #3 of 5 Old 06-05-2011, 08:10 AM Thread Starter
cmabolt
I was abbreviating. I used a code puller. PO4055, PO4032
cmabolt is offline
post #4 of 5 Old 06-05-2011, 09:32 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
P0432 (M)1/2 Catalytic Converter Efficiency. Catalyst 2/1 efficiency below required level.
SYMPTOM
P0432 - 2/1 CATALYTIC CONVERTER EFFICIENCY
SET CONDITION
As catalyst efficiency deteriorates, the switch rate of the downstream O2 sensor approaches that of the upstream O2 sensor. If at any point during the test the switch ratio reaches a predetermined value a counter is incremented by one.
POSSIBLE CAUSES
-Exhaust leak
-Catalytic converter 2/1 faulty
-Upstream O2 sensor older than downstream O2 sensor
-engine misfire or running condition
-large vacuum leak
-engine oil leakage into exhaust-valve guide, seals, piston rings
P0455 (M) Evap Leak Monitor Large. Leak Detected A large leak has been detected in the evaporative system.
Buy a new gas tank cap. Check the hoses and fittings from the Evap solenoid and LDP for loose hoses/fittings or damage.
Also check for disconnected or damaged wires.
CJ7-Tim is offline
post #5 of 5 Old 05-31-2012, 05:27 PM
SpideYJeep
Reviving old thread because I'd like to see what was the outcome of the smoke test as I just bought an '01 XJ which popped up the CEL and code a day after purchase.
Thanks!
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
Emission Delete Kit 88GTBlack XJ Cherokee Technical Forum 13 12-05-2012 07:33 AM
Emission problem morlhug XJ Cherokee Technical Forum 0 09-25-2009 01:03 PM
Emission Problems with no Cat? buckeye_1 XJ Cherokee Technical Forum 2 06-03-2006 04:06 AM
wa emission sucks ak90xj XJ Cherokee Technical Forum 23 05-25-2006 09:49 PM
emission equipment ricko70 XJ Cherokee Technical Forum 1 03-30-2006 04:29 PM
