emergency brake cables - JeepForum.com
post #1 of 8 Old 10-24-2006, 11:10 PM Thread Starter
oldjeepster
Just finished a 4.5 inch lift. The emergency brake adjustment is as loose as possible but cables are tight going to drum. Any suggestions on modification or maybe a replacement?
oldjeepster is offline
post #2 of 8 Old 10-25-2006, 01:22 AM
kroymander
are you sure it's not just the sheath around the cable?
93 ZJ Ltd, pretty stock
kroymander is offline
post #3 of 8 Old 10-25-2006, 06:09 AM Thread Starter
oldjeepster
That is correct. It is just the sheath around the cable.
post #4 of 8 Old 10-25-2006, 06:12 AM Thread Starter
oldjeepster
post #5 of 8 Old 10-25-2006, 10:12 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The passenger side of the Wrangler ebrake cables is longer than an XJ cable. Do some seaching on the web or take one to the parts store and compare. Buy 2 of the longer ones, they don't care which side they are installed on.
CJ7-Tim is offline
post #6 of 8 Old 10-25-2006, 11:02 AM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Yeah, YJ cables work fine. My stock cables/conduits were approx. 36" and acted as limiting straps. The YJ passenger side cables are around 57". They connect to the parking brake lever in the drum without any mods.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #7 of 8 Old 10-25-2006, 12:32 PM Thread Starter
oldjeepster
Thanks for the help. We are getting the YJ cables today.
post #8 of 8 Old 10-25-2006, 02:14 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
I used NAPA part #UP94371. Costs around $22 each.
To get the old one off I used a screw type hose clamp to compress the tangs (or whatever they're called) so it could slide out of the brake backing plate. I'm sure there are other methods, but this worked for me. You'll see what I'm refering to when you remove the drums.
'87 XJ 2" lift
'96 XJ stock
ChewyXJ is offline
NEED HELP! YJ Brake Cables On An XJ: 89SAFARIXJ XJ Cherokee Technical Forum 19 11-12-2008 09:34 PM
YJ e-brake cables? 89SAFARIXJ XJ Cherokee Technical Forum 3 09-26-2008 09:54 PM
Which parking brake cables? Alexia XJ Cherokee Technical Forum 3 09-06-2008 07:21 AM
Which e-brake cables? Muddy Cherokee XJ Cherokee Technical Forum 2 02-09-2007 06:19 PM
E-Brake Cables MSHarnett XJ Cherokee Technical Forum 1 03-06-2005 10:47 AM
