Emergency Brake button popped off, how to fix? - JeepForum.com
post #1 of 11 Old 06-25-2007, 01:31 PM Thread Starter
cardana24
Like the title says my emergency brake button came off. It shot off along witht he spring that is behind it. I have place it back where it is supposed to go but the break will not hold now. I can pull it up and there is resistance but it just falls back down. It will not hold its locked position. What can I do to fix this? By looking at the button and the plastic rod that it connects to, it looks like it broke off. Do I need another E-brake assembly? I have not taken anything apart yet, how much fun am I in for? Thanks for any help.
this is on an 1985 Cherokee 2 door, 5 speed.
cardana24 is offline
post #2 of 11 Old 06-25-2007, 01:50 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I had a similar issue. I pulled the center console out and replaced the Ebrake assembly with a junk yard unit.
Not hard to do, but it takes some time with all the screws that need to be removed.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 11 Old 06-25-2007, 01:53 PM Thread Starter
cardana24
all the screws that hold the center console down? I don't have carpet in the front of the jeep so it easier for me to get to all of this stuff. Do you know what year E-brake assemblies I can use? I have an 85. And does the ebrake cable disconnect on the handle or am I going to have to run a new cable too?
post #4 of 11 Old 06-25-2007, 04:06 PM
AZ Jeff
2014 JK Wrangler
There is an easier fix--reattach the button to the shaft with epoxy. Hold the button on until the epoxy cures with duct tape. Overnight will do just fine for restoring the button's function to like new.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 11 Old 06-25-2007, 04:11 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Shouldn't need a new cable. You'll see where the cable end feeds into the handle assembly. Take your old one with you to the junk yard. I'd assume a 84-86 woudl be a perfect match, but you may even be able to use a 87-90 or even a 91-96.
Try the above mentioned glue trick, but if that doesn't work hit the yards.
93 Sport
Specs in Profile.
balloo93 is offline
post #6 of 11 Old 06-25-2007, 10:12 PM
LorenII
LorenII's Avatar
1992 XJ Cherokee
same thing happened to me this weekend... only brake was set on the side of a hill on a trail... thank God for needle nose pliers! I'll try the glue thing first.
I now understand... Just Empty Every Pocket
LorenII is offline
post #7 of 11 Old 06-25-2007, 11:38 PM
Deeznuts
1994 XJ Cherokee
I just glued mine last week with some 15 minute plastic epoxy and it worked like a charm. The only thing that I had to do was sit there and hold the button for 5 minutes while the epoxy initally set up. Seems to be working great.
94 2 Door XJ, 4.5 rustys lift w/ full packs, cargar soft 8's, 33/12.50-15 Hi-tech D muds, Trimmed, Home brew bump stop extensions, Lots of rattles and creeks. D30 front with Aussie locker.
Deeznuts is offline
post #8 of 11 Old 06-25-2007, 11:45 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
My button went ballistic and flew out the window along with the spring. Junkyard fix worked for me.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #9 of 11 Old 06-26-2007, 07:42 AM Thread Starter
cardana24
I'll try the epoxy thing first then I will go to the junk yard if that does not work. It sounds like this is a common problem I did not think I would find that many people with this problem.
post #10 of 11 Old 07-04-2007, 12:29 AM
ar275103
1993 XJ Cherokee
junkyard fix is def. the way to go
ar275103 is offline
post #11 of 11 Old 07-04-2007, 12:36 AM
wojtizzlator
1987 XJ Cherokee
nah epoxy i broke the little thing in my shifter (automatic) and i superglued that baby in! if my ebrak worked i bet my button would break too little **** like that always happens to me!
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline
emergency brake jaygenesky XJ Cherokee Technical Forum 11 12-09-2009 03:35 PM
Button Issue with 'Release Brake' FM0722 XJ Cherokee Technical Forum 5 10-07-2006 08:54 PM
emergency brake? eclipse27 MJ Comanche Technical Forum 7 06-22-2006 09:10 PM
emergency brake kewlmonk2121 XJ Cherokee Technical Forum 2 07-01-2004 12:57 AM
Emergency Brake krs96XJ XJ Cherokee Technical Forum 9 03-08-2004 11:26 AM
