Eliminating the exhaust pipe - Page 3 - JeepForum.com
post #31 of 32 Old 05-25-2012, 12:52 PM
jeepkid03
Winning
jeepkid03's Avatar
Originally Posted by park308 View Post
Thanks I will probably be able to afford that one I have a 91 XJ 4.0
I forget on the early XJs if the O2 sensor is behind the cat in the exhaust pipe or in the cat convertor itself. If the sensor is in the pipe downstream, you could cut the pipe right before the sensor and put in this universal cat, which is slightly cheaper.
http://performance-curve.com/225goer...ter602545.aspx
If your O2 sensor is inside the convertor, you will have to use the convertor in the previous link I posted.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #32 of 32 Old 05-25-2012, 12:57 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
IIRC, the older XJ's didn't have a 2nd O2 sensor, so you can do without that. My 97 has a 2nd O2 in the cat.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
exhaust , louder , pipe
4 cyl exhaust pipe? ZeroGravity XJ Cherokee Technical Forum 0 12-19-2011 06:22 PM
4.0L XJ Exhaust Pipe OD? NWDave XJ Cherokee Technical Forum 7 04-25-2011 04:13 PM
2.5 vs. 4.0 exhaust down pipe 2002sport XJ Cherokee Technical Forum 2 06-04-2010 05:18 AM
Exhaust pipe size... mbood82 XJ Cherokee Technical Forum 0 08-17-2004 09:35 AM
Exhaust Pipe TPG013 XJ Cherokee Technical Forum 11 02-01-2004 01:20 AM
