Eliminating the exhaust pipe - Page 2 - JeepForum.com
post #16 of 32 Old 05-22-2012, 10:30 AM
dest
After running muffler-less for quite a while if you really want it loud just cut it off after the cat. You'll be able to tell how loud it is and make a decision from there. I've since put a dynomax exhaust on it and I think it's quieter than stock but it has been a while since I've had an exhaust on it...
dest is offline
post #17 of 32 Old 05-22-2012, 11:37 AM
98XJmtar14
Correct me if I'm wrong please because I might be crazy but like in_motion said if you were to just do straight pipe it would be loud and sound pretty decent I would think but I wouldn't do 3" pipe. Now this is where someone can tell me if I'm crazy or not because I might just have this all wrong but it makes sense to me...If you cut off everything from the just after the cat back and did straight pipe then depending on the size pipe you could still retain your back pressure. The way I see it the back pressure is the speed that the exhaust exits the vehicle completely so the muffler (pardon my crap metaphor) acts like an accident on the highway it slows everything down a bit but not completely so it keeps moving but it backs things up a bit. So assuming that that metaphor is correct if you were to use smaller pipe the exhaust wouldn't escape as quickly so the back pressure would be at least somewhat retained and you would get pretty freakin' loud exhaust that I think would still sound good.
I guess thats more of a question to you more wise jeepers and then if I am correct then an answer for the OP on what I would do, and personally I've wanted to do straight pipe with no cat or muffler just to piss everyone off lol but thats just me!
Inigo Montoya-Build Thread-99 XJ Sport
98XJmtar14 is offline
post #18 of 32 Old 05-22-2012, 12:44 PM
sAe23
1995 XJ Cherokee
Originally Posted by nwpipelayerxj View Post
You can take cat off anywhere without emission testing. Lots of places. Also, yeah the CO gas thing is stupid. BUT, if "I" were him looking for a little louder sound, I would take off everything behind the cat, and put a 90 sideways or straight down, then he still has all his o2 sensors hooked up and no thrown codes. Just a slight loss in back pressure. Best of both worlds. Just my .02
It is a crime under US Federal Law, punishable with a fine up to $25000, to remove a functional Catalytic Converter, and all emission control devices installed by the factory must remain on the vehicle.
Technically, Puerto Rico is subject to US Federal laws...
But, as some might say, it's only illegal if you get caught
As for the SOUND, IMHO any stock motor does NOT sound "cool" w/o a muffler.
You need an appropriate Camshaft, and preferably EIGHT cylinders!
Also, some might argue that insufficient back pressure might contribute to burnt exhaust valves
sAe23 is offline
post #19 of 32 Old 05-22-2012, 02:29 PM
Diamond-x
1991 XJ Cherokee
I'm used to the California popo where a modified exhaust is good for a fix-it ticket, all they need to do is take a quick look under the car. If it looks modified, you get the ticket. As previously mentioned it's also disrespectful to drone around town.
OK, OK, I'm off the soap box....
The 4.0l engine, or any engine for that matter, requires back pressure to build torque. If you were to simply remove the cat and muffler and run a straight pipe, your engine would run like crap and would have little to no low end torque. Also, with a very short muffler-less exhaust, cool air can flow backup the pipe and warp your valves when the motor is shut off.
So, to recap: There is nothing good that can happen if you remove your cat/muffler. Except it sounds neat-o to a teenager.
Diamond-x is offline
post #20 of 32 Old 05-22-2012, 03:28 PM
kg4kzv
1995 XJ Cherokee
Anyone tried the DynoMax VT. I like the idea of it if it works. I hate the droning that comes with most performance mufflers. Also it seems like it would be stealth like when your not standing on it.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #21 of 32 Old 05-22-2012, 07:08 PM
BlueRidgeMark
1994 XJ Cherokee
Originally Posted by Azzy View Post
CO leakage into the cabin of the jeep is obnoxious no matter where you live. So is the brain damage that comes with it.
Yes, and sometimes that brain damage comes in the form of having your skull plastered all over the road or a tree because the CO put you to sleep behind the wheel.
Running with your exhaust dumping out somewhere under the vehicle is just plain....
(get ready for it)
STUPID!!
Either get an aftermarket exhaust setup and do it right, or dont bother.
Yep. Aftermarket can be a great thing.
Butchering your exhaust system because you think it will sound "good" is just asking for a damaged engine or worse.
BlueRidgeMark is offline
post #22 of 32 Old 05-23-2012, 02:42 AM
WindsorRenegade
Hey; I never said it wouldn't hurt your brains. I agree with you 100%.
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #23 of 32 Old 05-24-2012, 07:52 PM
merdock69
If you take your exhaust off then the engine will suck cold air in the hot exhaust valves and they twist like pretzels!!!!
Just kidding... Don't be stupid, just buy glass packs or have the muffler shop install a dump before the cat....
merdock69 is offline
post #24 of 32 Old 05-25-2012, 07:35 AM
park308
1991 XJ Cherokee
So question if I were to take off my cat and install the flowmaster muffler would that not be good or could I take out the cat. Right now my muffler fell off and I have bought a new muffler to install but I think the cat is clogged/not working right
park308 is offline
post #25 of 32 Old 05-25-2012, 07:44 AM
Jeff9
I don't really understand what's to gain by taking off the cat. Not like someone is going to stick his head under your jeep and say "wow cool bro!"...there are plenty of legal mufflers that sound great.
Jeff9 is offline
post #26 of 32 Old 05-25-2012, 07:56 AM
park308
1991 XJ Cherokee
It rusted and I don't have the funds to buy a new one so my question is will it affect the motor in any negative way I am not trying to sound look cool I am trying to make it a dd all I want is functionality
park308 is offline
post #27 of 32 Old 05-25-2012, 08:27 AM
Pats94
Depends on the year. It won't affect anything except emissions on older ones. Just try to get 1 on as soon as funds allow.
You may be able to offset the cost of a new catalytic converter by scraping the old one. They will give you money for used catalytic converters.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #28 of 32 Old 05-25-2012, 08:28 AM
jeepkid03
Winning
jeepkid03's Avatar
You will set a Check Engine light. I'd just run one of these. It even has the O2 sensor bung.
http://performance-curve.com/425225-...nvertero2.aspx
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #29 of 32 Old 05-25-2012, 08:40 AM
park308
1991 XJ Cherokee
Thanks I will probably be able to afford that one I have a 91 XJ 4.0
park308 is offline
post #30 of 32 Old 05-25-2012, 08:57 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
*IF* I were going to ignore the legal questions, I'd replace the cat with a thrush glasspack style muffler, and put a 45 degree turn down coming off the muffler.
I've often wondered what an XJ would sound like if you put a glasspack where the cat is and then ran a decent muffler. After the glasspack burns out, it would basically be a resonator tube.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
exhaust , louder , pipe
4 cyl exhaust pipe? ZeroGravity XJ Cherokee Technical Forum 0 12-19-2011 05:22 PM
4.0L XJ Exhaust Pipe OD? NWDave XJ Cherokee Technical Forum 7 04-25-2011 03:13 PM
2.5 vs. 4.0 exhaust down pipe 2002sport XJ Cherokee Technical Forum 2 06-04-2010 04:18 AM
Exhaust pipe size... mbood82 XJ Cherokee Technical Forum 0 08-17-2004 08:35 AM
Exhaust Pipe TPG013 XJ Cherokee Technical Forum 11 02-01-2004 12:20 AM
