Eliminating the exhaust pipe - JeepForum.com
post #1 of 32 Old 05-20-2012, 02:22 PM Thread Starter
Inti
What would happen if I disconnected the exhaust pipe from the engine, or farther away from the engine? Would it kill my engine?
Edit:
Allright so, I won't disconnect it from the block, but what can I do to make the xj louder/sound good.
Inti is offline
post #2 of 32 Old 05-20-2012, 02:52 PM
blue96jeep
It would be loud as hell if any of it was removed before the muffler. If taken off at the engine the exhaust gases would be so hot it would destroy everything in the engine compartment.
blue96jeep is offline
post #3 of 32 Old 05-20-2012, 03:06 PM Thread Starter
Inti
I want to make it loud, so i'l be removing it before the muffler. But honestly I don't want it just to be loud, I want it to sound good. Any suggestions?
Inti is offline
post #4 of 32 Old 05-20-2012, 03:12 PM
Pats94
If you went faster than 55 the downward thrust of the escaping exhaust gas would left the entire front end off the ground...
Just kidding! Not good for the motor and the carbon monoxide would not be good for you. Not to mention you couldn't even hear yourself think!!!
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #5 of 32 Old 05-20-2012, 03:25 PM
WindsorRenegade
You don't mean straight off the block do you??
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #6 of 32 Old 05-21-2012, 01:47 PM
in_motion
Drop the coin on a Flowmaster, I've heard very good things about the exhaust note they give and they are a reliable brand. I had a Cherry Bomb on my 4 cyl that actually sounded nice and growly, without going all ricer-fart-can, if you don't want to throw down on a Flowmaster. Or just send 3" pipe out the back after the cat...
1996 XJ Country, 4.0, aw-4, 2wd :(
Previous rides:
1995 XJ SE, 2.5, ax-5, 231, cancerous unibod...traded^
1995 XJ Country, 4.0, aw-4, 231, babysat for brother...
in_motion is offline
post #7 of 32 Old 05-21-2012, 02:02 PM
buildin1XJ
Mufflers
Mufflers serve a purpose more than just making your ride quieter,They create a back pressure which the engine needs to run correctly,Personally I like my Dyno Max don't recall what model it is but good sound.
buildin1XJ is offline
post #8 of 32 Old 05-21-2012, 02:21 PM
BUSA
I just ordered as we speak a magnaflow cat & stainless flowmaster exhaust system set me back $570.00 but its all gd hope it sounds gd with the banks header i have...............
BUSA is offline
post #9 of 32 Old 05-21-2012, 02:31 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Loud doesn't equal good. Loud equals obnoxious and disrespectful. Respect your neighbors and keep it properly muffled.
In addition, it is illegal to remove the cat/converter.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #10 of 32 Old 05-21-2012, 07:27 PM
mwitkowski24
My muffler recently fell off and it sounded loud....but it def didn't sound good.
mwitkowski24 is offline
post #11 of 32 Old 05-21-2012, 07:43 PM
nwpipelayerxj
1997 XJ Cherokee
Yeah you disrespectful loud sob lol
nwpipelayerxj is offline
post #12 of 32 Old 05-21-2012, 08:42 PM
WindsorRenegade
Maybe here it is. But this guy is in puerto rico. I don't know if it matters there.
post #13 of 32 Old 05-21-2012, 09:04 PM
Azzy
CO leakage into the cabin of the jeep is obnoxious no matter where you live. So is the brain damage that comes with it.
Either get an aftermarket exhaust setup and do it right, or dont bother.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #14 of 32 Old 05-22-2012, 07:46 AM
nwpipelayerxj
1997 XJ Cherokee
You can take cat off anywhere without emission testing. Lots of places. Also, yeah the CO gas thing is stupid. BUT, if "I" were him looking for a little louder sound, I would take off everything behind the cat, and put a 90 sideways or straight down, then he still has all his o2 sensors hooked up and no thrown codes. Just a slight loss in back pressure. Best of both worlds. Just my .02
post #15 of 32 Old 05-22-2012, 08:41 AM
jeepkid03
Winning
jeepkid03's Avatar
This. Do it right or not at all. Flowmaster mufflers are loud but sound pretty good. If you hack off the exhaust it will be loud but sound like crap.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
exhaust , louder , pipe
4 cyl exhaust pipe? ZeroGravity XJ Cherokee Technical Forum 0 12-19-2011 06:22 PM
4.0L XJ Exhaust Pipe OD? NWDave XJ Cherokee Technical Forum 7 04-25-2011 04:13 PM
2.5 vs. 4.0 exhaust down pipe 2002sport XJ Cherokee Technical Forum 2 06-04-2010 05:18 AM
Exhaust pipe size... mbood82 XJ Cherokee Technical Forum 0 08-17-2004 09:35 AM
Exhaust Pipe TPG013 XJ Cherokee Technical Forum 11 02-01-2004 01:20 AM
