Electronic vs Thermal Flasher Question - JeepForum.com
post #1 of 4 Old 03-26-2008, 07:10 PM Thread Starter
slik97zj
1990 XJ Cherokee
Couldn't find the correct answer from searching. My Blinker thermal flasher died. Went to Auto Zone and they were out of the exact replacement. So I purchased an Electronic one. Will it matter to use either or as a direct replacement?? Thanks
slik97zj is offline
post #2 of 4 Old 03-26-2008, 07:38 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The electronic is actually better than the original style. If you tow a trailer or convert to LED's the original style flasher gets fooled into thinking you have a bulb burned out and it flashes super fast. The electronic one will work just fine.
CJ7-Tim is offline
post #3 of 4 Old 03-26-2008, 11:54 PM Thread Starter
slik97zj
1990 XJ Cherokee
Actually I do tow a small 4x8 trailer. I never really thought about it till this happened. I understand now! Thanks.
slik97zj is offline
post #4 of 4 Old 03-27-2008, 05:21 PM Thread Starter
slik97zj
1990 XJ Cherokee
Installed it today and noticed no major diference, only louder. I think I'll just replace the hazards with one similar.
slik97zj is offline
Thermal Insulation? Wazzuppiggy156 XJ/MJ Cherokee Non-Technical Forum 0 06-18-2009 09:44 PM
Fan clutch, thermal or non-thermal?? cubsin2079 XJ Cherokee Technical Forum 5 07-31-2008 07:15 PM
Experience/Opinions on using thermal insulation on the exhaust? lost honda pro XJ Cherokee Technical Forum 27 02-01-2008 09:33 PM
Electronic Flasher for XJ's LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 6 03-07-2007 06:45 AM
Thermal Fuse location on 98 XJ? cmassey_2001 XJ Cherokee Technical Forum 18 07-13-2004 11:19 PM
