Electrical questions - JeepForum.com
post #1 of 5 Old 03-04-2012, 04:26 PM Thread Starter
BigGreenoh9
1997 XJ Cherokee
I'm starting to tackle some of the electrical issues on my '97 Cherokee Sport.
1) I have power windows, and the switch stops working when you open the door. I'm thinking loose connection, but the switch ALWAYS works when the door is closed, and NEVER works when the door is open. Pass. side works great. Is it a bad ground in the harness i.e. the connection gets grounded through the latch striker when its closed? Any ideas where to start?
2) Looked at the fuses for some of the problem areas, like power mirrors and rear defroster that doesn't function. I replaced the missing fuse and now the defroster works, but still no power mirrors. Could this be related to the drivers door switch issues?
3) The courtesy lights all work with the headlight switch, and the dome lights work with the rear doors. BUT they do not work when the hatch is open, or when either of the front doors are open. Don't even know where to begin there.
Suggestions?
Current: 1997 XJ Sport 4x4 - 4.0/AW4/231
Previous: 1987 YJ - 4.2/BA10/207; 2005 WK - 5.7/545RFE/245
BigGreenoh9 is offline
post #2 of 5 Old 03-04-2012, 06:32 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Take the trim panel off the drivers door and inspect the wires. Issues with door wires are common. Look for chafed insulation, pinched or damaged wires, and failed wire splices. If the wires check OK consider that the master switch assembly on the door has failed.
Also check the pin switch in the door opening. If it is failed the dome light may not work. Inspect the switch on the cargo are dome lamp. Look for signs of burned or melted plastic.
CJ7-Tim is offline
post #3 of 5 Old 03-04-2012, 06:46 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
check the wires in between the door and body in the rubber boot,they tend to break and may not make contact when open but touch when closed.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #4 of 5 Old 03-04-2012, 08:30 PM
N8N
yeah, I'm thinking that it has something to do with a broken wire in the boot. It might be a busted ground wire - there is supposed to be a ground wire running through there but maybe that one is busted? There's a multi-pin connector behind the driver's side kick panel, if you disconnect that that'll give you more slack to work on it. I was actually just in there earlier today fixing a busted speaker wire... for some reason the wiring that Jeep used from the factory is a lot less flexible (fewer, bigger strands) than my roll of generic 16AWG speaker wire - so I expect my fix to be semi-permanent (until a different wire decides to give up.)
N8N is offline
post #5 of 5 Old 03-05-2012, 09:21 AM
habbyguy
Sounds like it could be a ground wiring problem. The latch will do a lot better job of grounding the door than the hinges will, which would fit your symptoms pretty well. A quick way to test this would be to connect a voltmeter between the chassis and the door frame, while pushing the window button. There should be almost no voltage showing up, but if you do get more than a fraction of a volt with the door open and the window button engaged, you'll know that the ground wire to your door has gone bad. The good news is, this will be one of the easiest electrical fixes you'll ever do on your XJ.
habbyguy is offline
1997 , electrical , issues
Electrical and Armor questions VTEK1 XJ Cherokee Technical Forum 3 05-02-2011 04:55 PM
Electrical Gremlins and an Electrical n00b Jesseman445 XJ Cherokee Technical Forum 0 02-23-2010 09:28 AM
electrical questions: fog lights dont work jerry4570 XJ Cherokee Technical Forum 19 11-21-2008 05:58 PM
SYE and CV Drive shaft Questions (and a questions for the Colorado guys) jaardesign XJ Cherokee Technical Forum 4 08-09-2004 11:14 AM
Electrical ? CDJEEP XJ Cherokee Technical Forum 8 01-07-2003 06:14 PM
