Electrical problems - JeepForum.com
post #1 of 12 Old 06-04-2012, 01:30 PM Thread Starter
inkei91
Electrical problems
I have a 2000 jeep cherokee sport 4wl drive. 4.0 6 inline cylinders.
i have owned this jeep for about 4-5 years and ever since ive had it, it has been teeming with electrical issues. for example: in one weeks time about 2 years ago i replace the idle air control 6 times because it kept going bad. i replaced the battery because the old one was about half the size it needed to be. eventually i replaced the pcm unit located by the air intake with a used one. im currently having many problems with cylinder misfire and emissions codes. i replaced both o2 sensors and it ran fine for about 24 hours then back to same ol same ol.also my a/c clutch and cooling fan only run if i jump the relays. but i will add that they both ran a year ago in the summer just fine. i just went on a long haul(1000 miles) and lost my cruise control, blowers stuck on defrost and no heat. everyone ive asked says bad ground. ive checked all the grounds i can find and they are all good. any suggestions? alternator? another bad pcm? Thanks in advance
inkei91 is offline
post #2 of 12 Old 06-04-2012, 05:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
On a 12 year old vehicle you should expect some additional maintenance compared to a newer vehicle. One at a time test and diagnose the symptoms and make the necessary repairs. The cruise control and the blower vents are run by vacuum, you have vacuum leak.
Read the JeepForum FAQ's, use the forum search function, use the Google.
CJ7-Tim is offline
post #3 of 12 Old 06-04-2012, 07:15 PM
cpttuna
I would replace all the grounds.
cpttuna is offline
post #4 of 12 Old 06-04-2012, 09:03 PM Thread Starter
inkei91
i agree on the maintenance. but i mean like the switch turn the blowers so they are at my feet or head. and i already stated all my grounds are good
inkei91 is offline
post #5 of 12 Old 06-04-2012, 09:04 PM
CJ7-Tim
CJ7-Tim's Avatar
CJ7-Tim is offline
post #6 of 12 Old 06-04-2012, 09:28 PM Thread Starter
inkei91
what about the misfiring? it was also backfiring from time to time when accelerating?
inkei91 is offline
post #7 of 12 Old 06-04-2012, 11:18 PM
Reptile
1991 XJ Cherokee
Engine control system, vacuum operated as well...
Reptile is offline
post #8 of 12 Old 06-05-2012, 08:49 AM
CJ7-Tim
CJ7-Tim's Avatar
Post the exact Check Engine Light trouble code numbers you are downloading.
CJ7-Tim is offline
post #9 of 12 Old 06-05-2012, 11:33 AM Thread Starter
inkei91
do you have any idea where the vacuum hose would be that would be leaking? they both went at the same time so im thinking its the same hose
and i got different codes from different readers ill go get them rechecked as i have been erasing them and seeing if they come back. Thank you btw
inkei91 is offline
post #10 of 12 Old 06-05-2012, 11:47 AM Thread Starter
inkei91
nvm i found on the side of my engine a totally disconnected hose! idk how it came off but i put it back on and bam! my blowers work fine. but now my biggest problem is that my a/c clutch and cooling fan only come on if manually jumped. im down in oklahoma city and its hot as hell! any thoughts as to why my relays are not engaging? test lighted where power comes into them and just a faint trace of juice. relays are all good
inkei91 is offline
post #11 of 12 Old 06-05-2012, 12:41 PM
CJ7-Tim
CJ7-Tim's Avatar
....my a/c clutch and cooling fan only come on if manually jumped.
If you are low on refrigerant, the compressor will not cycle. Have a shop test the the pressure or buy a kit with a tester. Do not overfill. Also test the high and low pressure switches and inspect the wire plugs/wires.
CJ7-Tim is offline
post #12 of 12 Old 06-05-2012, 01:16 PM Thread Starter
inkei91
i just had the refridgerant filled by a mechanic who also checked the high and low pressure switches. he said there was no power coming to the relay to turn it on. could this be my pcm? i replaced it a couple years ago
inkei91 is offline
cherokee , electrical , ground , jeep , wiring
92 XJ electrical problems kracer93 XJ Cherokee Technical Forum 0 05-03-2009 02:05 PM
window and locks problems electrical problems? mike243 MJ Comanche Technical Forum 1 04-05-2009 06:39 PM
Electrical problems!!please help natexj XJ Cherokee Technical Forum 2 11-13-2007 08:05 PM
Yay, more electrical problems... jbrem XJ Cherokee Technical Forum 2 01-14-2006 12:10 AM
Serious Electrical Problems! Help! nikota XJ Cherokee Technical Forum 14 10-13-2005 04:24 PM
