post #1 of Old 11-01-2010, 06:32 PM Thread Starter
pyrofighter06
electrical problems
my 98 xj with 190k has an electrical problem... somewhere between the main conrtol switch for the windows and the passenger rear window.. anyone else have any problems like this? it will roll down but not up..? i also seem to get a small shock every time i get out... one other thing ive noticed too is that my volt gage will bury in the 19 area from time to time for no reason.. my mechanic said its because of my optima battery and that it wont hurt anything.. any thoughts? Please!!!!
pyrofighter06 is offline
post #2 of Old 11-01-2010, 08:14 PM
Holder350
1995 XJ Cherokee
Almost all window issues like those you are having are due to broken wires in the harness going to the drivers door.
The static shock is nothing to worry with....
19v on your volt gauge is not because of your battery....sounds like you need a new mechanic....
Most likely is due to a bad ground on the cluster connection. Do a search for "no bus" and follow that fix
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of Old 11-01-2010, 08:25 PM
ChicoXJ
1986 XJ Cherokee
If the window will roll down and not up it is a switch. The wires are OK. Take your switch out and disconnect and reconnect the plug on the window switch. Sometimes this works. Also on 98s there is an issue with the lockout switch. Generally it takes out both functions though, but it could be it is the culprit too. To fix this, just wire around it.
ChicoXJ is offline
battery , electrical , help needed , short , window
window and locks problems electrical problems? mike243 MJ Comanche Technical Forum 1 04-05-2009 06:39 PM
Electrical Problems.. i think? Mtxz453 XJ Cherokee Technical Forum 2 11-24-2006 08:54 AM
electrical problems Backroads XJ Cherokee Technical Forum 2 09-12-2006 08:49 AM
More electrical problems... Tjs88xj XJ Cherokee Technical Forum 7 12-26-2005 12:33 AM
Electrical problems.......................... 4literbeater XJ Cherokee Technical Forum 0 12-17-2004 09:17 AM
You may not post new threads
You may not post replies
