Electrical ground points - Page 5 - JeepForum.com
post #61 of 69 Old 04-23-2013, 12:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Need to be on the engine. An EXTRA to the body is never a bad idea.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #62 of 69 Old 04-24-2013, 04:05 AM
cray101
Thanks cruiser54.
Is there another reason apart from the fact that it's the 'proper' way to do it?
I'd think that the engine and body are definitely connected to each other (electrially as well), so it shouldn't really matter where you ground it... I'll be happy to hear your thoughts!
cheers!
cray101 is offline
post #63 of 69 Old 04-24-2013, 06:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by cray101 View Post
Thanks cruiser54.
cheers!
Yeah there is. The engine and body are isolated via rubber mounts. And, even that crappy strap from the engine to chassis can cause issues. This is based on fact, experience, not book learning.
post #64 of 69 Old 04-24-2013, 08:03 AM
cray101
Makes sense. Thanks!
cray101 is offline
post #65 of 69 Old 02-15-2014, 07:47 PM
easttnkrawler
hey its taken me a while to even find anything on the driver inner fender grounds, my question is what do those 4 wires ground? I need to relocate them but I wanna know what exactly there grounding before I move them.
easttnkrawler is offline
post #66 of 69 Old 02-16-2014, 07:53 AM
CCKen
CCKen's Avatar
I responded to your other post about '97 G106 ground circuits.
CCKen is offline
post #67 of 69 Old 01-03-2016, 12:42 AM
jay7364
Are the grounds for the 2001 Cherokee XJ the same as the older models?
I have poured over the posts the last few weeks chasing a "no bus" issues. I cleaned the cluster contacts 4 times. I replace the CPS. I tightened the grounds at the engine strap (it was loose) and looked over all the other grounds indicated by Cruiser54. The vehicle will start and run and no more than 5 minutes into a trip the air bag will illuminate, the gauges will die (first the tach snd speedometer) then the airbag light, followed by the check engine light sonf finally the "no bus" indication.
I am convinced it is a ground issue and aside for the other previous stated ground, I cannot find the ground under the drivers side of the dash above the hood release handle. I am wondering if the gound is located elswhere on the 2001s v. the other models?
jay7364 is offline
post #68 of 69 Old 01-03-2016, 05:02 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This is one for CCKen.
post #69 of 69 Old 01-03-2016, 06:33 AM
CCKen
CCKen's Avatar
jay7364,
See my response to your question on the Other Jeep forum.
CCKen is offline
electrical issue , grounds , light dash electrical
Electrical? Ground? Fuses? So Lost... Wilmingtonite XJ Cherokee Technical Forum 0 08-22-2011 05:02 PM
Electrical Gremlins and an Electrical n00b Jesseman445 XJ Cherokee Technical Forum 0 02-23-2010 09:28 AM
Electrical Ground Help spyman22 XJ Cherokee Technical Forum 4 08-11-2009 06:35 PM
Tow Points cabbotts XJ Cherokee Technical Forum 11 03-09-2008 04:49 PM
Tow Points ilovexj's XJ Cherokee Technical Forum 3 11-28-2006 10:34 PM
