Electric fan relay - JeepForum.com
post #1 of 44 Old 07-07-2011, 05:45 PM Thread Starter
jdc48160
Electric fan relay
So, I've ALMOST got this problem solved with my girl's XJ.
New water pump since the old one had no fins left on the impeller, new thermostat, and cap. Still runs just a bit hot cuz the e-fan isn't kicking on.
So, I did a bit of digging, found a thread about a similar issue. Said to unplug the temp sensor on the thermostat housing and see if the fan kicks on. Unplugged it, fan came on. The thread said if the fan came on with the sensor unplugged, that the relay is bad.
Now, the fun part. All the stupid auto parts store websites only show the relay like the GRAND Cherokee takes that mounts behind the grille. NOT the XJ relay that goes in the PDC under the hood.
Does anyone have a part number for the XJ cooling fan relay? 1996 4.0 w/ac.
jdc48160 is offline
post #2 of 44 Old 07-07-2011, 05:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Printed right on the relay, isn't it ? Just go to the local parts store, they should have the one you need.
www.rockauto.com has brand names and part numbers, look it up.
If the you unplug the Coolant Temperature Sensor and the e-fan turns ON, the e-fan wires, e-fan relay, and the e-fan are good.
CJ7-Tim is offline
post #3 of 44 Old 07-07-2011, 06:39 PM Thread Starter
jdc48160
I'm just gonna have to go to the damn parts store. Rock Auto shows the same relay, the one that mounts behind the grille like on the Grand Cherokee, not the one in the PDC on the XJ.
jdc48160 is offline
post #4 of 44 Old 07-07-2011, 10:10 PM
medicmandan
medicmandan's Avatar
I had the same problem when I needed to replace my relay. Just take the old one into the parts store.
medicmandan is offline
post #5 of 44 Old 07-07-2011, 10:54 PM Thread Starter
jdc48160
Good to see I'm not alone with this issue.
jdc48160 is offline
post #6 of 44 Old 05-02-2013, 10:38 PM
Rescue XJ
I just found I am having the same issue, time to hit up Napa tomorrow.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #7 of 44 Old 05-03-2013, 11:48 AM
CCKen
CCKen's Avatar
So, I did a bit of digging, found a thread about a similar issue. Said to unplug the temp sensor on the thermostat housing and see if the fan kicks on. Unplugged it, fan came on. The thread said if the fan came on with the sensor unplugged, that the relay is bad.Now, the fun part. All the stupid auto parts store websites only show the relay like the GRAND Cherokee takes that mounts behind the grille. NOT the XJ relay that goes in the PDC under the hood.
"The thread said if the fan came on with the sensor unplugged, that the relay is bad."
This doesn't make sense. The fan gets it's power from the relay.
Could you post a link to the forum and thread that says this.
CCKen is offline
post #8 of 44 Old 05-03-2013, 11:52 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
Same here on my 2000.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #9 of 44 Old 05-03-2013, 12:42 PM
TheBoogieman
Devil's Advocate
I'm glad you brought up that point before I wasted $12.95 at Napa for a new one.I hooked my e fan to the battery and it's fine.It just doesn't come on by itself,ever.I'm a 6 x TJ guy and just learning the XJ problems.
post #10 of 44 Old 05-03-2013, 01:00 PM
TheBoogieman
Devil's Advocate
Bump!
Bump for a definitive answer.
post #11 of 44 Old 05-03-2013, 01:49 PM
CCKen
CCKen's Avatar
The E-Fan in your 2000 XJ will come on automatically under two conditions:
1. As a function of the AC System
2. When the engine coolant temp gets over 223*F
Here's an article that sort of explains how your 2000 AC System works.
http://www.askamechanic.info/askamec...nt/view/73/47/
Here's a procedure you can follow to see if the PCM is detecting a high coolant temp and turns the Fan on. Lots of people will tell you just to pull the connector off the ECT sensor and see if the fan runs. I see no real value in that procedure.
You'll need a 470 Ohm resistor (Radio Shack) to accumplish this test.
If the fan won't run in AC/Defrost or during the high coolant temp test, additional troubleshooting will be required.
CCKen is offline
post #12 of 44 Old 05-03-2013, 05:39 PM
CJ7-Tim
CJ7-Tim's Avatar
.... unplug the temp sensor on the thermostat housing and see if the fan kicks on.
If unplugging the temp sensor makes the e-fan turn ON, the relay, fan wires, and the e-fan are good.
If the e-fan does not turn on, the relay, fan wires, and e-fan are suspected to be faulty until testing proves otherwise.,
CJ7-Tim is offline
post #13 of 44 Old 05-03-2013, 06:21 PM
CCKen
CCKen's Avatar
TheBoogieman,
If using the popular process of unplugging the temp sensor on the thermostat housing and seeing if the fan kicks on doesn't make your fan kick on, I'm sure CJ7-Tim will be more than willing to walk you through the exact troubleshooting steps.
CCKen is offline
post #14 of 44 Old 05-04-2013, 08:03 AM
TheBoogieman
Devil's Advocate
If the e-fan does turn on, the relay, fan wires, and the e-fan are good. If it does not turn on, the relay, fan wires are e-fan are suspected to be faulty until testing proves otherwise.
Mine comes on when I do that.If I do the 470 Ohm resistor thing,what will that tell me? I'm stumped on what to do next.
post #15 of 44 Old 05-04-2013, 08:14 AM
CJ7-Tim
CJ7-Tim's Avatar
Boogieman I am not seeing your problem description and symptoms ?
CJ7-Tim is offline
AC Compressor Relay = Fan Relay medicmandan XJ Cherokee Technical Forum 1 07-20-2010 05:29 PM
Location of electric fan relay (it's running all the time) cardon XJ/MJ Cherokee Non-Technical Forum 2 07-07-2010 12:38 AM
90 cherokee 4.0 Electric engine fan hooked up wrong, need relay location. keepishop XJ Cherokee Technical Forum 0 10-26-2008 12:17 PM
Electric Fan Relay Chris_W_2k5 XJ Cherokee Technical Forum 4 05-02-2007 07:21 PM
Why a fuel pump relay output on my A/C Relay twisted_ed XJ Cherokee Technical Forum 0 04-02-2005 03:11 PM
