Electric Fan Operation on 2000 Cherokee - JeepForum.com
post #1 of 5 Old 04-21-2008, 08:42 PM Thread Starter
RodB
I've seen different responses on this question so would appreciate clarification on what should be the normal operation of the electric fan on my 2000 Cherokee Sport with the 4.0 liter engine. Should the electric fan come on automatically when the A/C is running, regardless of coolant temperature, or does it only run when the coolant reaches a certain temperature? And if so, what is that temperature?
Thanks in advance for any information provided.
RodB is offline
post #2 of 5 Old 04-21-2008, 08:43 PM
geewally9
I think it's when the engine reaches a certain temp, not sure what exact temp that is though.
geewally9 is offline
post #3 of 5 Old 04-21-2008, 08:52 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Electric fan will cycle on and off while the AC / Defrost is on. It will run constantly above 220 deg (approx).
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #4 of 5 Old 04-21-2008, 09:51 PM
EricsXJ
The Post man
EricsXJ's Avatar
When in doubt, consult your FSM. The answer is on page 7-9.
In a nutshell it says that with or without the AC on, the electric cooling fan turns on when the coolant temp is at least 223* F and remains on until the temp drops to 217* F or below.
What is confusing is the next sentence which states it will come on if the AC system pressures reach 300 +/- 20 psi and continue to run until pressure drops to 235 psi.
They make it sound like these conditions are independent of one another but I'm betting that if your AC pressures are that high that the fan would turn on, the engine temps would likely already be in the range for it to turn on as well. And as a caveat, I know nothing about the AC system...
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #5 of 5 Old 04-21-2008, 10:20 PM
tangofox007
You won't make any money on that bet.
tangofox007 is offline
1990 Cherokee - What is Proper Brake Pedal Operation? jeepcher XJ Cherokee Technical Forum 1 02-22-2009 07:28 PM
98 cherokee Aux Electric Fan dajeepman XJ Cherokee Technical Forum 0 03-19-2008 07:16 PM
2000 Cherokee Sport Changed Electric Fan / New Fan Won't Run LHA XJ Cherokee Technical Forum 6 08-08-2007 09:08 AM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 12:00 PM
2000 Electric Fan Question SID297 XJ Cherokee Technical Forum 2 04-13-2006 07:19 AM
