Electric Door Locks Intermittent - JeepForum.com
post #1 of 7 Old 09-04-2012, 12:01 PM Thread Starter
rsurran
So my electric door locks don't operate sometimes from either the remote (horn sounds) or the door lock buttons. Before I start into the wiring diagrams I thought someone might be able to tell me right off if there is a relay and if so where it is located. I have done two searches and not got anything worth while.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #2 of 7 Old 09-04-2012, 12:43 PM
keepishop
1989 XJ Cherokee
Usually just applying white lithium grease to all of the locks' moving parts will help significantly.
Try just spraying the door latches while locking and unlocking each door for a $3 first round.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 7 Old 09-04-2012, 12:46 PM
Fezwick
I have the same problem. The relays are in the passenger's side door switch panel. I don't think they're replaceable though. Sometimes if I wiggle the switch I can get the locks to work again. Do you hear the relay click when you hit the switch?
My guess is the whole passenger side panel is going bad. The entire power lock circuit runs through the passenger side panel. So if it goes bad, you won't have power locks. I'll check the wiring first to make sure, though.
Fezwick is offline
post #4 of 7 Old 09-04-2012, 01:52 PM Thread Starter
rsurran
No the relay is not clicking. When I use the remote, the horn sounds but none of the doors lock. When using the lock button inside, nothing happens.
Dick Surran
rsurran is offline
post #5 of 7 Old 09-04-2012, 01:53 PM Thread Starter
rsurran
Sometimes it all works fine.
Dick Surran
rsurran is offline
post #6 of 7 Old 09-04-2012, 04:40 PM
Fezwick
It's possible that the wiring between the kick panel and door is bad on the passenger side. You'll have to poke around with a multimeter and see if it's getting juice. This is straight from the 2000 FSM.
PASSENGER DOOR MODULE
The Passenger Door Module (PDM) contains the passenger side front door power lock switch and the power lock system control circuitry. In its role as a power lock switch, it provides the power lock system control circuitry with a ground path through the PDM ground circuit and the driver side power lock switch contacts to indicate a lock request or unlock request.
In its role as the power lock control module, the PDM receives inputs from the battery, the ignition switch, the DDM, the driver door ajar switch, the key-in ignition switch, and the headlamp switch. It also receives a hard-wired input from the RKE receiver, if the vehicle is so equipped. In response to these inputs, the PDM sends the proper outputs to control the power lock motors through its integral power lock and unlock relays. The PDM power lock system functions can be tested as outlined below. If the power lock system operates, but the RKE system lock and/or unlock functions are inoperative, see the diagnosis for the Remote Keyless Entry Transmitter in this group.
(1) Check the fuse in the junction block. If OK, go to Step 2. If not OK, repair the shorted circuit or component as required and replace the faulty fuse.
(2) Disconnect and isolate the battery negative cable. Remove the passenger side front door trim panel and unplug the 8-way PDM wire harness con- nector (C-1) from the PDM. Check for continuity between the ground circuit cavity of the 8-way PDM wire harness connector and a good ground. There should be continuity. If OK, go to Step 3. If not OK, repair the open circuit to ground as required.
(3) If the problem being diagnosed is inoperative power lock switch illumination, proceed as follows. If the problem is not power lock switch illumination, go
to Step 5. Connect the battery negative cable. Turn the ignition switch to the Accessory or On positions. Check for battery voltage at both sides of the power window circuit breaker in the junction block. If OK, go to Step 4. If not OK, replace the faulty circuit breaker.
(4) With the ignition switch still in the Accessory or On positions, check for battery voltage at the fused ignition switch output circuit cavity of the 8-way PDM wire harness connector. If OK, replace the faulty PDM. If not OK, repair the open circuit to the junction block as required.
(5) If the problem being diagnosed is an inopera- tive door lock inhibit feature or a power lock system that responds to an Unlock command, but not a Lock command, proceed as follows. Otherwise, go to Step 7. With the driver side front door closed, check for continuity between the door ajar/key-in circuit cavity of the 8-way PDM wire harness connector and a good ground. There should be no continuity. If OK, go to Step 6. If not OK, repair the shorted door ajar and/or key-in ignition circuits as required. Refer to Group 8U - Chime/Buzzer Warning Systems for more infor- mation.
(6) Open the driver side front door with the key in the ignition switch or with the headlamp switch in the On position. Check for continuity between the door ajar/key-in circuit cavity of the 8-way PDM wire harness connector and a good ground. There should be continuity. If OK, go to Step 8. If not OK, repair the open door ajar and/or key-in ignition circuits as required. Refer to Group 8U - Chime/Buzzer Warning Systems for more information.
(7) Connect the battery negative cable. Check for battery voltage at the fused B(+) circuit cavity of the 8-way PDM wire harness connector. If OK, go to Step 8. If not OK, repair the open circuit to the fuse in the junction block as required.
(8) Test the PDM power lock switch continuity through the two PDM wire harness connector recep- tacles. See the PDM Power Lock Switch Continuity chart (Fig. 2) to determine if the continuity is correct in both the Lock and Unlock switch positions. If OK, see the diagnosis for Power Lock Motors in this group. If not OK, replace the faulty PDM.
Fezwick is offline
post #7 of 7 Old 09-05-2012, 02:55 AM Thread Starter
rsurran
Many thanks Fezwick. I'm hoping for a bad ground.
Dick Surran
rsurran is offline
Electric locks jkhjeep XJ Cherokee Technical Forum 1 11-22-2009 12:03 AM
Electric door locks? jackedupxj XJ Cherokee Technical Forum 3 12-25-2008 09:55 AM
Electric Locks Not Working xjrrrdx XJ Cherokee Technical Forum 3 04-24-2007 07:48 PM
electric door locks PO-Dan XJ Cherokee Technical Forum 1 06-14-2006 07:53 AM
Question about electric door locks...... Lonestar XJ Cherokee Technical Forum 4 04-04-2003 12:11 PM
