Are Either Of These Engines Direct Fit? - JeepForum.com
post #1 of 7 Old 07-30-2012, 07:23 AM Thread Starter
Nate_nev
1997 XJ Cherokee
I have a 1997 XJ and having a constant stalling issue that I have spent enough money on (can be seen on my other thread) and now looking to swap motors with a running cherokee..
the cherokees that I have access to are 1994 XJ and a 1995 grand cherokee.
are either of these direct fit swaps or is there anything "special" I would have to do with these?
thanks ahead of time for the help.
Nate_nev is offline
post #2 of 7 Old 07-30-2012, 07:59 AM
Garvin
1986 MJ Comanche
Both engines will fit but you will need to swap the parts from your engine over to these ones (intake, exhaust, sensors, etc). If you're looking for a direct swap with everything then you'll be looking for '97-mid '99's.
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #3 of 7 Old 07-30-2012, 09:37 AM Thread Starter
Nate_nev
1997 XJ Cherokee
thanks for the information.
Nate_nev is offline
post #4 of 7 Old 07-30-2012, 06:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wondering why you are going to randomly install an engine instead of diagnosing and repairing the issue that leads to the stalling ? Seems like a lot of work and no benefit. Stalling is most likely a sensor or electrical issue.
CJ7-Tim is offline
post #5 of 7 Old 07-30-2012, 09:01 PM
1995_XJ
1995 XJ Cherokee
I agree. A whole swap seems unnecessary. Mine stalled when I first got it, changed the TPS and cleaned the throttle body and its been fine for a year now. Not saying that its one of those two, but could be a simple fix.
What have you tried so far? Im no expert but Im sure someone on here can help you
1995 Cherokee Sport
1995_XJ is offline
post #6 of 7 Old 08-01-2012, 01:48 PM Thread Starter
Nate_nev
1997 XJ Cherokee
All if the sensors are brand new, all grounds are replaced, fuel pressure is where it is supposed to be, full tune up, re-indexed timing, traced and cleaned all connections etc.. etc.. i have spent more than enough money and time... and honestly giving up at this point and want 4x4 back because my daily driver at the moment is my 93 ranger low rider show truck..
refer to my thread of everything I have done, if you have any other ideas I would gladly try them.
http://www.jeepforum.com/forum/f11/s...-hand-1386981/
Nate_nev is offline
post #7 of 7 Old 08-01-2012, 01:54 PM
cbenez1
Fate and or murphy's law will probably kick you square in the *** if you swap a whole motor due to stalling. In other words the chances of the problem being something not internal with your old engine are quite high. You might go thru all that trouble and end up with the same symptom and that would truly suck.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
compatibility , engine swap
XJ D44 direct swap? Max713 XJ Cherokee Technical Forum 4 02-06-2010 09:15 PM
96 4.0 to 94 4.0 direct swap? KrayZ XJ Cherokee Technical Forum 6 03-05-2009 09:33 PM
Direct Fit vs Universial Jeepokee XJ Cherokee Technical Forum 2 01-07-2007 03:23 PM
Direct link to SYE kit anywhere? Xride XJ Cherokee Technical Forum 2 12-12-2006 01:15 PM
Direct Fit CAT for 01? Jeppy XJ Cherokee Technical Forum 7 05-11-2006 11:38 AM
