Edge Trail Jammer kit? - JeepForum.com
post #1 of 24 Old 08-23-2010, 03:57 PM Thread Starter
Armyboy1911
well one of my friends told me this would be a god kit to get some more power from my XJ. i have a few questions though.
what size is the TB bore? and do you guys/girls like this kit?
did you see any gains or feel them?
thanks!!!
2000 Jeep TJ 4.0L, 5 speed
Patriot blue
Armyboy1911 is offline
post #2 of 24 Old 08-23-2010, 04:31 PM
cornbrizzle
1992 XJ Cherokee
The chip will do nothing much for a 4.0l , you can get your TB bored yourself for less than 100.00 . And don't worry about the warm air intake it won't do a lot for you. And to top it off if you improve your air intake it dosn't do anything if you don't improve you exhaust,
just my .02
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 24 Old 08-23-2010, 04:44 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
X2 don't waste your money on the chip.
xjfever is offline
post #4 of 24 Old 08-23-2010, 04:48 PM
jeepkid03
Winning
jeepkid03's Avatar
ehh that kit isn't worth the money for what it will do... which isn't much.
Heres how to get the most power without stroking the motor:
-Cold Air intake, with a shield so it actually gets cold air
-Bored out throttle body
-High flow cat convertor
-2.5" cat back exhaust
-tune up with new plugs, wires, etc.
-run some fuel system cleaner through it to clean out your injectors
A chip won't do much for the 4.0L. It is an old design closer to a tractor motor than a modern car engine, so the easiest way to get more power is the old fashioned way.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #5 of 24 Old 03-07-2011, 04:20 AM
stretchtj
im looking at it and they don't make one for a 96 cherokee but would the 97 retrofit with little or no modification
stretchtj is offline
post #6 of 24 Old 03-07-2011, 08:33 AM
dukie564
1995 XJ Cherokee
chips don't do anything except waste your money on our engine
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #7 of 24 Old 03-07-2011, 08:45 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can buy it and throw it in the back seat. You will get pretty much the same result as having it installed. Your best bet for better performance is a bored throttle body, and free flowing exhaust. If you have larger than stock tires regearing the axles to match tire size will be the most effective gain in power.
xjfever is offline
post #8 of 24 Old 03-07-2011, 11:24 PM
stretchtj
well power is nice but im also looking for efficiency and a s
post #9 of 24 Old 03-07-2011, 11:25 PM
stretchtj
post #10 of 24 Old 03-07-2011, 11:41 PM
robsjeepxj
The only thing that the chip does that helps at all is it raises the transmissions shift threshold meaning it holds it in gear longer so you can get up to a higher RPM before it shifts. The higher the RPM and the later it shifts the faster it will be in racing type scenario, this is useless for a jeep since almost everything out there is going to faster anyway. So yes it's pretty much a waste of money.
robsjeepxj is offline
post #11 of 24 Old 03-08-2011, 08:08 AM
stretchtj
yea that makes sense
post #12 of 24 Old 03-08-2011, 08:36 AM
96jeepxjcbc
or u can do wat i did. 4.2 crank, bored .40 over, special ground cam, flat top pistons, msd dis.,mustang 5.0 32 lbs. inj.,bored out tb, ported and polished head, block and head has been decked. header, 2.5 in exhaust,edge programmer, nos, and warm air induction.
about 550 hp. for about $6,000. and i get 17 mph
ROSCO.96 Jeep xj. 2in CBC lift, CBC air intake, CBC rims, and CBC exhaust.
96jeepxjcbc is offline
post #13 of 24 Old 03-08-2011, 09:16 AM
dukie564
1995 XJ Cherokee
You unfortunately cannot have the best of both worlds. Generally if you increase power, efficiency decreases. The opposite is generally also true.
dukie564 is offline
post #14 of 24 Old 03-08-2011, 10:47 AM
BeepBeepGoJeep
1994 XJ Cherokee
Yea the 4.0 really is more of a tractor engine than anything lol, and it doesnt really respond well to mods like alot of engines will.
[]IIIII[]
BeepBeepGoJeep is offline
post #15 of 24 Old 03-08-2011, 12:19 PM
Chelsea
The clocks ticking, pops.
Chelsea's Avatar
1999 MJ Comanche
This is the truth. I did all of this for my Jeep, and it does make a difference. the Edge kit will do nothing for you, it's kind of a waste of money.
Chelsea
2005 WK Limited, 5.7 hemi, QDii, aFe intake, Magnaflow exhaust, Taylor shorties, Diablosport tuned
1999 XJ Sport, trail rig, lots of goodies
Chelsea is offline
Edge Trail Jammer problems? winks00XJ XJ Cherokee Technical Forum 9 06-12-2011 04:01 PM
Edge Trail Jammer ?s jbramble24 XJ Cherokee Technical Forum 5 01-10-2009 11:13 AM
yay or nay on the edge trail jammer pack? Meanpuddin XJ Cherokee Technical Forum 5 08-12-2008 09:31 PM
Edge Products Trail Jammer with Throttle Body and Intake System rehberg79 XJ Cherokee Technical Forum 5 06-24-2008 08:02 AM
Edge Trail Jammer!! jeepin4evr XJ Cherokee Technical Forum 5 09-12-2005 02:30 PM
