eAutoWorks Headlight Harness No High Beams - JeepForum.com
post #1 of 3 Old 01-31-2011, 07:24 AM Thread Starter
adkjeepxj
Finally got around to installing my eAutoWorks headlight harness and wow the low beams are bright and work great, my only problem is the high beams dont work. I swapping which plug goes into which relay but I had the same outcome with great low beams and no high beams. Could it be a bad relay?
I suck withe electrical stuff so any help would be appreciated
adkjeepxj is offline
post #2 of 3 Old 01-31-2011, 08:33 AM
jeeptorino68
1992 XJ Cherokee
could be a bad relay, grab one from the XJ, like for the aux fan or something and try it out.
do you have DRL? i have heard this can mess it up, but im not sure.
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #3 of 3 Old 01-31-2011, 08:54 AM Thread Starter
adkjeepxj
No i dont have DRL i will try and a new relay and see if that works.
Which eAutoworks Headlight Harness? XtrailratedJ XJ Cherokee Technical Forum 306 12-08-2011 04:13 PM
Anyone know if the same EAutoWorks headlight harness for an XJ works on an MJ? ex4rings MJ Comanche Technical Forum 4 12-03-2010 07:30 PM
Eautoworks headlight harness install problems Moose_God XJ Cherokee Technical Forum 20 10-23-2010 03:31 PM
EAutoworks wire harness and stock headlight fitment TitanUranus XJ Cherokee Technical Forum 3 08-11-2010 02:42 PM
eAutoWorks Harness 97XJnoobie XJ Cherokee Technical Forum 7 01-07-2010 11:38 AM
