Easy 4 Wheel Drive Test - JeepForum.com
post #1 of 20 Old 11-01-2010, 02:47 PM Thread Starter
leichte
I have a 1987 Laredo and have doubts that the 4WD is working. Since I don't have a mud pit or off-road area, is there an easy way to test if 4WD is working?
Many thanks!
Clarke
leichte is offline
post #2 of 20 Old 11-01-2010, 03:08 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Get somewhere of the pavement, put it in 4wd, and give it some gas. You'll know for sure.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 20 Old 11-01-2010, 03:09 PM
Green4dr
pull it to 4hi then try to make a tight turn going slow. if you hear binding or feel it then your 4 is working. o
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #4 of 20 Old 11-01-2010, 03:12 PM
gonejeepin04220
1995 XJ Cherokee
if its an auto. (or good with a stick) POWERBRAKE IT!! put it in "4wd" . put it in drive, push down firmly on the brake pedal. and at the same time push the gas pedal..if you spin the tires (rear) and your sitting still then your not in 4wd. if you were in 4wd it would move without a problem. thats the easiest thing i can think off. or jack all four tires off the ground and put it in 4by and then drive and see if the front tires are spinning
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #5 of 20 Old 11-01-2010, 03:30 PM
Topgun514
1988 XJ Cherokee
Put your back tires on blocks and put it in 4...if your Jeep comes off then your front engages! Dont break something to test out 4x4, just put the back up with teeny bottle jacks that your jeeps came with and drive off them. They wont hit your Jeep because they will fall over- everything is safe!!!
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #6 of 20 Old 11-01-2010, 04:35 PM
cumminsjeep24
1997 XJ Cherokee
put it up on jack stands, put it in 4wd and let off the brake
97XJ 97TJ 11WK2
KCCO
cumminsjeep24 is offline
post #7 of 20 Old 11-01-2010, 04:45 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
the last two seem unsafe to me.
x2 on just finding some dirt or gravel and just punch it in 4WD, youll know for sure. or if there is no dirt in the area, just remove the rear driveshaft(youll lose a little fluid from the t-case), and try to drive in 4WD. then top of the t-case appropriately
1990JEEPXJ is offline
post #8 of 20 Old 11-01-2010, 08:35 PM
ChicoXJ
1986 XJ Cherokee
Put it in 4WD, jack up one front wheel and see if you can spin it by hand. If you can, it is not in. This is the only definitive and safe way to do it on a rig without lockers.
ChicoXJ is offline
post #9 of 20 Old 11-01-2010, 09:22 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
that is also a good way. but they way i described is not unsafe in any way. though the way you described is probably best
post #10 of 20 Old 11-01-2010, 10:24 PM
BeepBeepGoJeep
1994 XJ Cherokee
put in 4wd turn all the way in one direction, then try to lurch forward real quick when turned on full lock, youll know whether or not if its working then.
[]IIIII[]
BeepBeepGoJeep is offline
post #11 of 20 Old 11-02-2010, 07:50 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
x2 on this. Don't break something just to test it out.,
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #12 of 20 Old 11-02-2010, 07:56 AM
lowicz96
1995 XJ Cherokee
Hey black mountain isnt from from me, well i move from asheville to hendersonville but still isnt to far away. I know theres dirt roads out there you can tear down to see if the 4x4 works
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #13 of 20 Old 11-02-2010, 09:59 AM
2000BB6
always a good way to find out
2000 XJ
2000BB6 is offline
post #14 of 20 Old 11-02-2010, 02:26 PM
jkh
Disconnect the rear driveshaft and put it into 4hi. If you go anywhere, it works
Jason
'98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's
'81 Honda GL500
Colorado Jeep Club Member #399
jkh is offline
post #15 of 20 Old 11-02-2010, 03:42 PM
foggybottombob
As it leaks ATF fluid out the back of the tcase. Not a good idea.
foggybottombob is offline
4 wheel drive , 4wd , four wheel drive
98 XJ Test Drive D-BOI XJ Cherokee Technical Forum 18 05-08-2009 11:13 AM
about to buy...test drive ?'s sbrunner XJ Cherokee Technical Forum 9 05-21-2008 11:28 PM
How do you drive your XJ, easy? hard? Dannyboy18 XJ Cherokee Technical Forum 55 05-01-2007 03:33 PM
What to look for in a test drive jrmyrnsm XJ Cherokee Technical Forum 3 08-22-2005 08:54 PM
Test drive questions bigsparky XJ Cherokee Technical Forum 10 06-27-2005 09:36 AM
