E-brakes cable help - JeepForum.com
post #1 of 8 Old 05-09-2012, 08:43 PM Thread Starter
dillonreid
1992 XJ Cherokee
E-brakes cable help
Im swapping my dana 35 with a 8.25 and was wondering if my emergency brake cables would work in the 8.25. Thank you
http://www.jeepforum.com/forum/f22/my-jeep-geoff-texas-build-1348154/
dillonreid is offline
post #2 of 8 Old 05-10-2012, 09:55 AM
donthelegend
Yep, they'll work just fine.
donthelegend is offline
post #3 of 8 Old 05-10-2012, 10:06 AM Thread Starter
dillonreid
1992 XJ Cherokee
So my Cherokee being a 92 and the 8.25 being from a 2000 wont effect it at all? Thanks for the help
post #4 of 8 Old 05-10-2012, 10:15 AM
Ben
The e-brake cables on the 2000 axle aren't going to be the right length, the drivers side will be too short.
At 3" of lift, you would probably want a pair of passenger sides late model cables.
Ben is offline
post #5 of 8 Old 05-10-2012, 10:15 AM
donthelegend
I'm almost positive that the axle end e-brake connections are the same across all years, but I'm not 100%, sorry. I know they are the same on '97+ but I don't have experience with the earlier models (have never seen anything about the e-brake cables mentioned in any of the swap threads though, so I've never seen anyone mention any differences).
post #6 of 8 Old 05-10-2012, 10:27 AM Thread Starter
dillonreid
1992 XJ Cherokee
Well the 2000 doesn't have the cables but mine are less than a year old so didn't really wanna buy new ones unless I have to. If I do have to get new ones where should I get some?
post #7 of 8 Old 05-10-2012, 10:36 AM
Ben
If yours are less than a year old, try to re-use them.
You would probably just need to work something out with the little spring hangers at the body, so they don't melt to the muffler.
Ben is offline
post #8 of 8 Old 05-10-2012, 10:51 AM Thread Starter
dillonreid
1992 XJ Cherokee
Thanks I may try to make some brackets and a heat sheilds for the muffler.
88 Cherokee brakes, replaced almost everything, still weak brakes, ARGGH!!! raymoore XJ Cherokee Technical Forum 8 10-06-2011 11:56 AM
Cable Bedozx6r XJ/MJ Cherokee Non-Technical Forum 0 07-22-2011 12:23 PM
Where does this cable go? bahamasjeep XJ Cherokee Technical Forum 8 02-26-2010 09:08 PM
Back drum brakes to disc brakes Mtxz453 XJ Cherokee Technical Forum 17 12-24-2005 09:17 PM
Perfomance Brakes/BNig Brakes twisted_ed XJ Cherokee Technical Forum 2 01-23-2005 11:27 AM
