Durango Gear Box / ZJ Steering Bar Swap Afterthoughts - JeepForum.com
post #1 of 71 Old 04-03-2011, 10:18 AM Thread Starter
dukie564
1995 XJ Cherokee
Thought I would post some information / thoughts that I gathered this weekend whilst swapping my XJ steering box for a Durango box. I also chose to swap in a tie rod from a v8 ZJ, and add a power steering cooler to the mix at the same time. So here are my thoughts / findings:
First the steering box swap. The new box I pulled out of a 99 Dodge Durango with the v8 engine. A 1998 Durango will work also as long as it's the non-plow version. Wow what a pain that was - the durango not only has a crossmember directly beneath the box and drag linkage, but it also has 2 pitman arms, one on the box, the other attached to the frame, making it a huge pain to separate where the joints (no room for a puller to fit). Eventually got it off after a bunch of banging and swearing. I also grabbed a tie rod from a V8 Grand Cherokee ZJ. Actually i'm joking, i grabbed the tie rod, sway bar, and drag link because i wanted to compare them all to the stock XJ components.
Sooo...
Durango Box on the left (freshly cleaned and painted), stock XJ box on the right.
The Durango box has exactly the same mounting and length, but as the picture may/may not show, the Durango cylinder is much bigger than the XJ's - almost 1/4" bigger. In this case bigger = stronger, thus the upgrade.
Onto the linkages/sway bar.
After removing my stock XJ linkages, i compared them to the ZJ linkages i pulled from the yard.
First the sway bay - i thought this would be exactly the same, but it wasn't. The ZJ bar is shaped completely different, and although the mounting points are the same, the bar ends that attach to the links are angled very differently. On a stock height XJ, this means the mounting points are much higher when that bar is rotated to the same place. Perhaps this bar can be used on a lifted XJ instead of extending the links? Someone want to test this out?
So pictures: ZJ is the black one on top, XJ is a rusty one on the bottom
Exactly the same size bar as a 1995 XJ Sport:
ZJ:XJ:
Next the drag link - mostly exactly the same, the only difference seemed to be the angle of the attachment point for the steering stabilizer...not a big deal. XJ top, ZJ bottom
Exactly the same size bar:
ZJ:XJ:
Onto the REAL upgrade, the tie rod. The ZJ rod is 1/8" thicker, and SOLID. Compared to the XJ's tie rod it was huge and much beefier. The proof is in the pictures: XJ top, ZJ Bottom:
ZJ bar is 1/8" larger diameter:
XJ:ZJ:
So now that we have that settled, my components are set: ZJ Tie Rod, XJ drag link, XJ sway bar, Durango Steering Box. All in a fresh coat of paint and new poly joint boots. Mmmmm yummy.
Now to attach the new, stronger steering box to the frame, i decided to reinforce the mounting point a bit, and at the same time get rid of the crappy stock aluminium spacer. C-ROK sells an awesome steering box reinforcement plate system. I opted for just the inner plate since my wheeling isn't too extreme yet, and future plans for a off-road bumper will occupy the spot used by the outer plate. The inner plate comes with 3 frame sleeves also, which get inserted before the bolts are put though. It also utilizes the very strong stock tow point bolt, adding an extra bolt. All this means that any load going through the steering box off-road will be distributed better along the frame rather than just at the bolt holes.
As you can see this thing is pure beef - 3/16 plate
Now the bigger dimensions of the durango box require the use of some additional spacers - i found 2 washers to be the perfect amount. You're going to need 3 new 7/16"-14, 4" long grade 8 bolts to get enough length, and also a 9/16" bolt for the tow point hole. Here you can see it in place:
And....BAM!
I at one point had found a writeup, i believe on Stu Olsen's Jeep site, where he had installed a power steering cooler. I though why not, it's a great idea, and certainly can't hurt to cool the fluid better when you're offroad at low engine speed. So when i was at the junk yard i also picked up a tranny cooler off a random truck - any will work as long as it's a good size to fit. I put mine inside the radiator support beam, and using some new transmission line, spliced it in line with the low pressure return for the steering box.
So here's the finished product. I think it looks pretty damn sexy.
So now the effects. I've driven it a few times over the past couple days, and my impression is wonderful. Overall the steering feels tighter, and i can now turn corners using two fingers. The ratio seems tighter also, it only takes 1/2 turn of the wheel to turn a sharp 90* onto a side road, and the truck doesn't seem to want to drift as much side to side. Overall a great mod that I can't wait to test out off-road. It's a lot of work, but well worth it.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #2 of 71 Old 04-03-2011, 10:31 AM
BayouBengal85
impressive sir (in chester cheetah voice, lol). looks good. im currently acquiring all the steering parts to do the zj conversion on my 96 xj sport. really liking the red too
96 2wd XJ Sport, 4dr, 4.0HO, Auto, 3.55 gears,117k Miles
15x8 Canyon Rims
31x10.50x15 TreadWright Warden AT's
Fram Air Hog Filter
Magnaflow Hi Flow Catalytic Converter
Dynomax Superturbo Catback Exhaust
BayouBengal85 is offline
post #3 of 71 Old 04-03-2011, 10:37 AM Thread Starter
dukie564
1995 XJ Cherokee
all you need is the tie rod
dukie564 is offline
post #4 of 71 Old 04-03-2011, 10:45 AM
BayouBengal85
im going to be changing the ends and some other parts since my xj is 15 yrs old and none of the steering components have ever been changed (still handles great though, just time to upgrade)
15x8 Canyon Rims
Fram Air Hog Filter
post #5 of 71 Old 04-03-2011, 07:57 PM
EricsXJ
The Post man
EricsXJ's Avatar
Nice write-up. I added it to the Tech/FAQ links sticky.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #6 of 71 Old 04-03-2011, 09:49 PM Thread Starter
dukie564
1995 XJ Cherokee
sweet!
dukie564 is offline
post #7 of 71 Old 04-03-2011, 10:28 PM
_Trucker
'Bigger Member'
_Trucker's Avatar
1989 XJ Cherokee
Great write up.
Thom
NAXJA member # 3388
_Trucker is offline
post #8 of 71 Old 04-03-2011, 11:46 PM
toyotaguy
Great write up, thanks! But for some reason the pictures aren't showing up for me, not sure what's going on....
toyotaguy is offline
post #9 of 71 Old 04-04-2011, 06:14 AM
Bfleig
1990 XJ Cherokee
Any chance you know what year Durango I could use the box for my 1990 XJ? My steering is very sloppy.
Thanks
Bfleig is offline
post #10 of 71 Old 04-04-2011, 08:14 AM Thread Starter
dukie564
1995 XJ Cherokee
1998 V8 Durango Non-Plow, or 1999 V8 Durango.
I've also heard 1997 works too, but cannot confirm
dukie564 is offline
post #11 of 71 Old 04-04-2011, 08:47 AM
justanotherjpr
Nice write up on this install.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #12 of 71 Old 04-04-2011, 10:23 AM Thread Starter
dukie564
1995 XJ Cherokee
well i wasn't exactly planning on turning this into a full install write-up, but since the masses demand satisfaction, i am further adding to the detail. I didn't document every step, but i did take a few more pictures while doing the work so here they are for your pleasure....
Here's a before picture, notice the abundance of power steering fluid soaked parts
Here's a shot of the power steering lines. The High pressure line is the front port, the return in the rear port. Do NOT switch these when you hook everything back up. You need an 18mm stubby wrench. I didn't have one, so my adjustable stubby crescent had to do. To install the cooler i used a hack saw to cut the metal return line right before it turned back toward the rear of the vehicle, and clamped on the new rubber line.
At this point with everything disconnected, the weight of the tires took over, and turned my jeep into a retarded looking abomination. I had a good laugh...
Got the stock steering box out without too much fanfare. I had pretreated all the bolts for the week prior with a good helping of PB blaster twice a day, so no issues there. The hardest part was holding up the box while trying to separate the steering shaft from the box - this is one point at which i wish I had someone there assisting from above (the second time being sliding the shaft onto the new box, which was even worse). I will make a point to note - be sure you remove the pitman arm nut and pull the arm BEFORE unbolting the box. Also, when you're pulling the arm, leave the nut threaded on a little bit so the pitman arm doesn't go flying across the parking lot when it explodes off the shaft (ask me how i know). Also seen here is the crappy aluminum spacer (which i recommend you replace) - mine came off intact, many will not.
Ok so now to compare the box's range. Note that the range is slightly bigger than what is shown due to the wheel returning a bit at full lock (no one to hold the wheel all the way turned), but should give a good comparison. They are very close to being the same.
Stock XJ Box:
Durango Box:
And...that's all I got for you.
dukie564 is offline
post #13 of 71 Old 04-04-2011, 10:51 AM
Ben
which comes in 3 parts, if you order it new.
the rod itself, the connecting sleeve, and the rod end.
you can order all that new for under $100.
dukie, is the rod end of the V8ZJ the same as the XJ drag link rod end at the pitman arm?
yo, it's fun trying to hold the box up, hold the little spacer thing between it & the frame, and slide the bolt in with the other hand, ain't it?
Ben is offline
post #14 of 71 Old 04-04-2011, 11:01 AM Thread Starter
dukie564
1995 XJ Cherokee
It looks to be the same, but i make no guarantees
dukie564 is offline
post #15 of 71 Old 04-04-2011, 11:05 AM Thread Starter
dukie564
1995 XJ Cherokee
just checked the parts catalog - as long as it's the v8 ZJ end yes it's the same part # as the xj drag link end
dukie564 is offline
durango , power steering conversion , zj tie rod
Durango steering Porkmaddox XJ Cherokee Technical Forum 8 01-31-2011 01:24 PM
durango steering box mud-dog27 XJ Cherokee Technical Forum 3 03-04-2010 07:50 PM
Durango steering box in an XJ Grinola XJ Cherokee Technical Forum 11 05-19-2009 06:38 AM
Durango Steering Mod FrankZ XJ Cherokee Technical Forum 8 04-16-2007 11:36 PM
steering box swap from durango any done it mikeypmcg XJ Cherokee Technical Forum 3 12-22-2005 08:22 AM
