Dull Horn Problem - JeepForum.com
post #1 of 7 Old 10-13-2009, 07:43 PM Thread Starter
JRS0428
Dull Horn Problem
The battery in my XJ seems fine but the horn when i lock the doors, press the panic button and use the horn in the steering wheel all sound very dull and weak. Something isnt right? any ideas? Thanks.
Joseph The Jewish Jeep!
JRS0428 is offline
post #2 of 7 Old 10-13-2009, 07:57 PM
Lupitaboy
You have two horns, one in each corner pocket at the front and they toot at different pitches to combine into that rather downscale sound they produce to keep us safe from harm. Often, one or both of the wires attached to one or the other of these units comes loose leaving only the one horn blaring rather weakly. If both wires are securely attached, then it usually is a loose ground wire since the power travels to the horn and then uses the xj body as the complete circuit, thereby requiring a ground to the body to allow it to work. If none of the above, then one of your horns has been stolen or is deceased.
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks
Lupitaboy is offline
post #3 of 7 Old 10-13-2009, 08:13 PM
amw_drizz
1997 XJ Cherokee
Yup I had that issue on one of my diesels Could barely hear the horn over it running. When I put new batteries in the truck I noticed one of the horns was disconnected. Reconnected it and wham it just became the loudest horn in the yard.
Mine -> 1997 Jeep Cherokee Sport, 4.0 Command-Trac Auto, My parents -> 2002 Jeep Grand Cherokee, 4.0 Selec-Trac auto.
amw_drizz is offline
post #4 of 7 Old 10-13-2009, 10:04 PM
Rural-Assault
i had mud in my horn and you could hardly hear it. Try checking to see if it has mud clogged in it.
XJ SPORTŪ 8" on 36's Geared,Locked & Caged
Rural-Assault is offline
post #5 of 7 Old 10-13-2009, 10:08 PM
Mickey_D
I just said, "Screw it" and unplugged the stock horns. There's a nice set of Fiamm air horns under there now. As soon as I get the proper solenoid valve they'll be hooked into my onboard air system.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 7 Old 10-14-2009, 12:07 AM Thread Starter
JRS0428
i'd love that but im 16 and until i find a job im not going to be able to do anything to my XJ
JRS0428 is offline
post #7 of 7 Old 10-14-2009, 12:08 AM Thread Starter
JRS0428
thats most likely what happened, tommorrow ill have to check and see, thanks
JRS0428 is offline
Dull Headlights taylorC XJ Cherokee Technical Forum 4 09-08-2009 07:46 PM
Dull Body Side Moldings mshaab XJ Cherokee Technical Forum 21 08-19-2007 10:38 AM
Dull Hum 1990JEEPXJ XJ Cherokee Technical Forum 4 11-12-2006 08:26 PM
Horn Relay? (Horn off with Ignition Off) 90XJ RickyN29 XJ Cherokee Technical Forum 0 09-09-2006 11:50 PM
Horn Problem nascar XJ Cherokee Technical Forum 1 04-14-2006 10:19 PM
