dual exhaust 4.0 - JeepForum.com
post #1 of 13 Old 12-19-2010, 06:22 PM Thread Starter
1moneypitt
1991 XJ Cherokee
dual exhaust 4.0
Has any one done this? i think it would sound supper chunky if it was split 3 into one and 3 into another. run them all the way out that way. if you have do you have pictures/ audio of this?
1moneypitt is offline
post #2 of 13 Old 12-19-2010, 06:25 PM
jeg57
ive seen a few wranglers with it done. Never a cherokee. It might have somewhat of a power issue if you use the 3 inch pipe.
jeg57 is offline
post #3 of 13 Old 12-19-2010, 06:28 PM
austin6137
1990 XJ Cherokee
If they did it would most likey sound like crap
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #4 of 13 Old 12-19-2010, 06:28 PM
BeepBeepGoJeep
1994 XJ Cherokee
i dont think duals are for a cherokee, at all, they dont make very good power that way and its hard to route, i believe they also sound a bit ricey with duals
[]IIIII[]
BeepBeepGoJeep is offline
post #5 of 13 Old 12-19-2010, 06:28 PM Thread Starter
1moneypitt
1991 XJ Cherokee
not saying 3 inch pipe. just from the manifold running say cylinders 2,4,6 into one side of duals and 1,3,5 into the other side.
post #6 of 13 Old 12-19-2010, 06:29 PM
austin6137
1990 XJ Cherokee
I think he means 3 cylinders on one pipe 3 on the other
post #7 of 13 Old 12-19-2010, 06:31 PM Thread Starter
1moneypitt
1991 XJ Cherokee
^^^ exactly
post #8 of 13 Old 12-19-2010, 06:58 PM
austin6137
1990 XJ Cherokee
Something like this would work. I think banks makes it, they include a y pipe but it's a start
post #9 of 13 Old 12-19-2010, 07:26 PM Thread Starter
1moneypitt
1991 XJ Cherokee
thanks! thats exactly what im looking for. drop the y pipe and if i could fit it all the way keep them dueled!
post #10 of 13 Old 03-11-2011, 07:24 PM
63FI
1990 XJ Cherokee
Yea, maybe dual?
OK guys here I go. It's a '90 Cherokee I call my beater. Has 200K+ on it.
My stock exhaust was pretty well rotted out from the cat back, so it was pretty much like open exhaust after the cat. My gas mileage was very good for this car though. ( I have 3 others that suck on mpg) I got never less that 22 and as high as 28 on a trip keeping at or under 60mph. OK, now I decided to re-join society and put on a muffler and make it blend with everyone else. Bought a turbo muffler and pipes so it sounds like it should. It sounds OK but now my mileage is mostly 17 and never more than 20mpg.
OK, so Why am I on here telling you this? I thought dual exhaust would be all over here for the increased mpg and possible power increase. Looks like nobody really tried duals? Has anyone done a before and after mpg after doing exhaust mods? I'll tell you, I like my Jeeps but HATE getting ripped off every time I go to the gas station, so I'm interested in trying something to battle the 4/gal that is not too far off. Anyone tried anything?
63FI is offline
post #11 of 13 Old 03-12-2011, 01:26 AM
xj_army
duals wont really do nothing for u. The bigger the pipe the better high end power and loss of low end torque which IMO is where you need it in a jeep.
#83
xj_army is offline
post #12 of 13 Old 03-12-2011, 02:40 AM
Dbiked
I've read somewhere on here that with the 4.0, If you Dule pipe it, it could cause some kind of back pressure issue that could effect it negatively in some way. Sorry for the exeptional vaugness of this post. I'll go look for the thread to find out exactly what it said.
Its funny, I've seen this thought come up a couple of times on here, and for one reason or anouther it gets shot down fairly quick, i think this is the longest i've seen a thread on this subject stay so positive.
Utah jeep crew member #32
Dbiked is offline
post #13 of 13 Old 03-12-2011, 02:48 AM
Dbiked
Here we go. Check this out there are some of the negatives in there. Just to play devils advocate for a bit.
http://www.naxja.org/forum/showthread.php?t=2165
Just thought of another issue. What would you do about your O2 Sensors? It just doesn's seem worth it. Again, Just being the devils advocate, not trying to compleatly shoot you down here.
Dbiked is offline
XJ Dual Exhaust?? OffroadAlex XJ Cherokee Technical Forum 4 10-02-2009 06:24 AM
dual exhaust aircruiser XJ Cherokee Technical Forum 20 05-29-2008 10:05 PM
Dual Exhaust? wannaxj XJ Cherokee Technical Forum 10 10-22-2003 02:33 AM
Dual Exhaust.....Should or Shouldn't titus95 XJ Cherokee Technical Forum 2 02-03-2003 09:13 PM
Dual Exhaust? Glare231 XJ Cherokee Technical Forum 1 05-28-2002 08:36 PM
