Dual Battery w/ battery in the trunk - JeepForum.com
post #1 of 3 Old 12-08-2008, 10:23 AM Thread Starter
laxsmith23
So I done some searches and found plenty of threads on dual batteries but i want to run duals with a snorkel that needs the stock airbox so i was thinking about putting the battery in the trunk. I found this setup:
http://www.go.jeep-xj.info/HowtoBatteryDual.htm
I like it but i wanted to know what you guys think. I would fab up a box and mount it in the corner that the spare used to be in but would there be a problem with ampage because of the long cables or would it be fine. I would install the 12v guys dual battery + winch switch so there would be a lot of wire and I was thinking that there may be a problem with that. what do you guys think?
laxsmith23 is offline
post #2 of 3 Old 12-08-2008, 05:11 PM
jwarfield
I don't think there will be a problem with the location, just make sure you use big enough wire. I've relocated batteries in several vehicles including 4WD's and SCCA race cars with no problem. First, use a brand new battery, you don't want any nasty fumes in the cabin of your rig. Second, use 4 gauge wire, you can pick it up pretty cheap at a welding supply store for a lot less than you might think. I think I paid something like .60 cents a foot, plus when you get welding wire its a lot more flexible so you can jam it around corners and in tight places. I can't stress safety enough, make sure you mount the batt. box securely and about once a month inspect the battery to make sure there are no leaks in the cabin.
Good luck!
Never trust a man in shiny shoes or a clean hard hat.
92 XJ-Toy
95 ZJ-Daily Driver (bad on gas)
09 Genuine Roughhouse 50 scooter-Daily Driver (good on gas)
jwarfield is offline
post #3 of 3 Old 12-08-2008, 05:57 PM Thread Starter
laxsmith23
Good luck!
Yea. i plain on mounting the box to the side mount for the spare and the bottom mount for the spare with a storage area in it. but where it doesnt take up any more room then the spare. But thanks. I think that I might even use 2 gauge but ill be taking a trip to my local steal place for the wire. thanks
Dual battery ProMod1385 XJ Cherokee Technical Forum 4 02-13-2008 07:00 AM
Dual battery with one battery in the rear. Atticus1354 XJ Cherokee Technical Forum 2 11-25-2007 12:36 AM
once again battery in the trunk... white_elephant XJ Cherokee Technical Forum 5 07-09-2007 08:43 PM
battery in the trunk.. white_elephant XJ Cherokee Technical Forum 6 07-04-2007 11:57 AM
dual battery set up amaple XJ Cherokee Technical Forum 4 04-15-2002 10:33 AM
