Drum brakes write-up. hope it helps
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
yea i was writting this write up but i deleted it by accident. anyway, long story short i need to do the drum brakes. heres a write up for it. the parts i got
-new drums -shoes and lining -new harware -brake adjuster cable -few bucks -friend that works at monroe as assistant manager and the right tools. you can make do by jacking up the rear and supporting the frames on jackstands. chock the wheels. mine was put on a lift in the shop after hours. hehe ![]() goin up... ![]() remove wheels and inspect what else might need looking over and fixin. look at those herendous leaf packs. so sad, theyre causing me some wierd vibes. remove the drum. a few whacks of the BFH and it was off ![]() start taking the parts off after studying it so u know how to do it on the other side. i suggest you do one side at a time. we had four guys workin. goin out for drinks so the job got done quicker this way. broken brake adjuster cable ![]() remove wheel cylinder. you will need to bleed the brakes if youre replacing these. ![]() emove wheel cylinder. you will need to bleed the brakes if youre replacing these. ![]() new wheel cylinder. ![]() start reassembling in reverse order. needle nose pliers and vicegrips help lots. along with a brake puller. ![]() puting parts together with new hardware ![]() new adjuster cable ![]() 10 pic limit
She's a 96, 4.5 inches on 33's. 30 front, 44 rear, armored & wishin i can wheel it like i stole it. my build http://www.jeepforum.com/forum/f11/96-perrywinkle-build-thread-634491/ |
#2 |
![]() ![]() i mixed up the last 2 or 3 pics but the order are around the same its just the adjuster cable being put on. look at them new drums. oooo yea ![]() wheels back on. after bleeding the brakes, adjust them and fill the master cylinder with brake fluid. ![]() so lift is next hopefully this sat cause im actually off work and i got time and the weathers been nice. hope this helps for those who needs it.
#3 |
Nice write-up with pics. It should definitely help people, especially since you show plenty of pics.
#4 |
wow cool.
make sure to keep that buddy of yours close ![]()
1993 3dr XJ i6 4x4 , in the works but road-going :p MY THREADS [url]http://www.jeepforum.com/forum/showthread.php?t=520942[/url] [url]http://www.jeepforum.com/forum/showthread.php?t=515576&page=2[/url] [url]http://www.jeepforum.com/forum/showthread.php?p=4827827#post4827827[/url] [url]http://www.jeepforum.com/forum/showthread.php?t=521632[/url] |
#5 |
If you submit this into the Tech Articles section and it gets accepted, you'll get a free upgraded one year membership... just some food for thought.
Nice writeup btw.
North Jersey Jeep Club Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs |
#6 |
dave, how do i do that?
#7 |
holy inverted leaf spring batman!
but in all seriousness, nice write up
Homebrew Discos- - '01 Intake Install - -S-10 Bastard Pack - -LeBaron Hood Vent Install- - Bored TB - - OE '93 onto '97 Tow Hooks - -Trans Cooler & Temp Gauge Install My Jeep HE15MAN |
#8 |
OH! Thank god! Im gonna do mine when this rain stops, I have never done it before and this actually is the best write up i have seen for rear brakes. Awesome Jeep by the way! Did you Black out the emblems?
#9 |
yea it was my first time as well. i had a friend help me who knew what he was doing so it helped a lot. also to have all the parts needed and the right tools. but simple hand tools are fine. thanks for the props guys
#10 |
Good write up. While you had it all apart, you should have taken a wire brush to the backing plates, especially the rusty parts where the brake shoes rub up against it. We also use a little dab of white lithium grease in the same spots, which helps the brake shoes slide back and forth.
You could have also covered the bleeding process for the wheel cyls and also the adjusting of the shoes to the new drums. And don't forget to get that grease off of your new shoes using some Brake Kleen.
91 Cherokee Laredo
Alpine sound system Hella 500s Rubicon wheels w/30" Destination A/Ts RE 2" BB and shocks Last edited by AlexsXJ; 03-19-2008 at 08:51 PM.. Reason: I'm bored. |
#11 | |
98 XJ, perpetually on jackstands |
#12 |
Go to this link, and post up the Tech Article in a new thread.....
http://www.jeepforum.com/forum/f141/
#13 |
Nice pics. Just did my brakes and r/w cylinders this weekend. Doncha just hate drum brakes? Thanks for the photos.
'96 Cherokee Country, Borla Cat Back, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. Only 80K miles - the wife uses it ('cept when I borrow it to go huntin') |
#14 |
not a bad write up, ive been putting off doing mine because its not exactly the most fun, especially since its been so hot out.
Baltimore County Jeep Club "A squid eating dough in a polyethylene bag is fast and bulbous. Got me?"
#15 |
How do I know if I have 9 or 10 inch brakes?
What do I measure? The shoes or the drum?
1998 Chili Pepper Red Cherokee 2in lift pics http://www.jeepforum.com/forum/f11/2-lift-pics-please-524372/ What will my XJ look like with.xx lift http://jeepforum.com/forum/showthread.php?t=525877 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
