Drum Brake Size in 95 XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Drum Brake Size in 95 XJ
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 06-08-2010, 07:04 PM   #1
Beta144
1995 XJ Cherokee
I need to replace the drum brake shoes in my 1995 XJ since i'm pretty sure they're completely worn out. When I went to Advance Auto Parts today and got them to look up the parts in their system it came back with two options for the rear drum brakes. There's a nine something inch and a ten something inch option. Is there some way to figure this out without taking the tire off? I don't want to buy the wrong part.
Thanks a lot.
Beta144 is offline   Reply With Quote
Unread 06-08-2010, 07:14 PM   #2
xjfever
1995 XJ Cherokee
If you have smooth drums it is 9" brakes, fluted or finned drums are 10" brakes.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
