drum brake help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > drum brake help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 05-31-2012, 09:39 PM   #1
TheAquatard
drum brake help
So after months of driving with my grinding Dana 35 I finally found a used 8.25. The drums are seized to the shoes from sitting in the guys garage for a month. I broke one free after hours of slow progress on the adjuster star. The other one I can't get to budge. I depress the retaining clip and try to turn the star but the brake spoon just slides up the gear :/ super fustrating, I doubt its moved at all. I've been smacking it and drentching the whole drum for 3 days. Any other options? Angle grinder time?
TheAquatard is offline   Reply With Quote
Unread 05-31-2012, 10:12 PM   #2
lsmurphy
If all else fails............angle grinder are a wonder thing.
I had one that was froze at the hub. I used an air hammer with a blunt tool and gave light hits all around the hub, came lose in seconds.
lsmurphy is offline   Reply With Quote
Unread 05-31-2012, 11:17 PM   #3
BleepinJeep
1988 XJ Cherokee
you could try heating it, or try using a sledge.
Website - [url]http://www.bleepinjeep.com/[/url] - The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube - [url]https://www.youtube.com/user/bleepinjeep[/url] - Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline   Reply With Quote
Unread 06-01-2012, 08:18 AM   #4
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are you sure you are turning the star wheel the correct direction ? Often a straight screwdriver works better than an adjuster spoon.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 06-01-2012, 04:10 PM   #5
TheAquatard
I ended up cutting a slit with the angle grinder into the drum, prying it open torelieve tension while a buddy hit it with an electric cement chisler. It fell off! The star adjuster was a solid piece haha thanks for the help guys.
