Dropped pitman arm - JeepForum.com
post #1 of 5 Old 12-27-2012, 10:21 PM Thread Starter
bht911sc
Dropped pitman arm
Has anybody added a dropped pitman arm on there Xj? I have a 91 Xj with a R/E 3.5 soft ride, I also have a 1 inch spacer with adjustable track bar. It seems to wander a bit at 20-35 mph needing steering correction more than I like. I was wondering if the extended arm will help with that issue..
bht911sc is offline
post #2 of 5 Old 12-28-2012, 07:47 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The XJ Cherokee does not need a drop pitman arm until about 6-8 inches of lift.
You should have 1/16-1/8" of toe-in. Not having enough toe-in or having worn steering components can cause, or contribute to, wandering.
CJ7-Tim is offline
post #3 of 5 Old 12-28-2012, 07:51 AM
pokeyxj
I don't think the pitman arm will help. First check all the steering linkage, tie rod ends, ball joints, steering gear and wheel bearings for play. Fix these first. If you still have the problem it could be the caster is off. The cure could be as simple as using longer lower control arms.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline
post #4 of 5 Old 12-28-2012, 09:48 AM
GetLifted
I needed a raised pitman arm
GetLifted is offline
post #5 of 5 Old 12-28-2012, 10:15 AM Thread Starter
bht911sc
Thanks people I'm gonna give it a closer look,the steering box is rebuilt, but I still have the same joints on the linkage.
bht911sc is offline
