Drop Bracket Install - JeepForum.com
post #1 of 25 Old 07-17-2008, 10:47 PM Thread Starter
btfury
I'll be installing drop brackets on the XJ tomorrow, and was just wondering how much time I should allot... Obviously it's different for everyone, just wanted to get a general idea. I'm guessing a couple hours?
Silver 2000 XJ Classic, NP 231, D30/Aussie, Chrysler 8.25, C4x4 Tow Hook Brackets, Optima Yellow Top, RE 4.5in SF and RE CA Drop Brackets, 32x11.5 BFG MT, RE HD Adj Trac Bar, OMEs, SYE and front DS, C-Rok Steering Brace, AJs Superrails, Precision 4.56s
btfury is offline
post #2 of 25 Old 07-17-2008, 11:20 PM
the_weirdo
the_weirdo's Avatar
I spent 4 hours on it, but I also added spacers and UCA's. I also had to run to the hardware store. I would think you can probably do it in 2.5-3hrs max.
the_weirdo is offline
post #3 of 25 Old 07-19-2008, 09:37 PM Thread Starter
btfury
this is probably common sense, but I tend to lack that sometimes... I'm finally getting around to starting the install on my drop brackets. My questions is this: The RE instructions call for the vehicle to be supported by the frame. Can I not just leave one tire on, take the other off, support that side using a jackstand under the axle, and install the DBs one side at a time like that? am i missing something?
btfury is offline
post #4 of 25 Old 07-19-2008, 10:20 PM
gijazbo
just do it from the frame it will make it easier to line the holes back up and move the axel around.....is the problem that you dont have jack stands?
It sucks to own a jeep in NE Ohio
MOPAR.... Made Of Paper clips And Rubber bands
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
My build thread:
gijazbo is offline
post #5 of 25 Old 07-20-2008, 07:12 PM Thread Starter
btfury
I got it figured out. I do have another question, however... I don't have the braces yet, but will I be fine driving around without them (no wheelin or anything...)?
btfury is offline
post #6 of 25 Old 07-20-2008, 07:25 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
as long as you have the lower arms connected in the stock location and your front end is aligned you'll be fine driving it on the road.
xjfever is offline
post #7 of 25 Old 07-20-2008, 09:26 PM Thread Starter
btfury
... wait a minute... so basically I can't install the drop brackets without the braces? How would I be fine driving around with the Drop Brackets if I have to put the lower arms in the stock location?
btfury is offline
post #8 of 25 Old 07-20-2008, 09:45 PM
chance_p
2008 WK
I wouldn't do it.
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is offline
post #9 of 25 Old 07-20-2008, 10:19 PM Thread Starter
btfury
Really? why do they sell the DBs separately from the brackets then?
btfury is offline
post #10 of 25 Old 07-21-2008, 09:36 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
That's exactly why I only listed them together on our site for a long time. MJs have reinforcement bracketry around the LCA mounts from the factory, so they won't need (and can't use) the DB braces, so that's one reason why the DBs would be listed separately.
Driving around town for a bit you'll probably be OK without the braces (I'd certainly try to get them installed ASAP though). TrailMaster's original DB design never included braces, though they did develop a reputation for eventually tearing LCA mounts off.
Not sure if you've seen these yet or not, but here's photos from when I installed the RE DBs on my rig:
http://jeepin.net/fotos/installs/rexjxd?g2_page=3
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #11 of 25 Old 07-21-2008, 03:51 PM Thread Starter
btfury
Thanks for the input, Jason. Yeah, I really wish I could install the braces, as well.. But unfortunately they're not here yet, and I've got to drive the Jeep tomorrow and I already started installing the DBs, so its not like I can go back (already drilled out the UCA mount).
Hopefully I'll be alright on the highway...
btfury is offline
post #12 of 25 Old 07-21-2008, 04:15 PM Thread Starter
btfury
For the record, I just spoke to RE, and they said I would be fine driving on the street and even light wheeling without the braces.
btfury is offline
post #13 of 25 Old 07-21-2008, 04:32 PM Thread Starter
btfury
anybody know torque specs for control arms?
btfury is offline
post #14 of 25 Old 07-21-2008, 05:29 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
sorry, I just reread your post. I initally thought you said the drop BRACKETS weren't there yet and that you were asking if driving with the stock mounts would be okay with your lift. I must have been half asleep, when I read your post.
xjfever is offline
post #15 of 25 Old 07-21-2008, 05:30 PM Thread Starter
btfury
Also, what's the best way to get the control arms to mount back up... If I unbolt the other lca and leave the other uca on, will it be easier to get the side im working on to mount up?
btfury is offline
drop bracket fisher2985 XJ Cherokee Technical Forum 0 02-01-2010 08:19 AM
Installing rustys adj track bar. How to install? Use drop bracket? Help ASAP! Element96x XJ Cherokee Technical Forum 11 07-22-2009 12:45 PM
RE arm drop bracket ? JR1 XJ Cherokee Technical Forum 6 06-24-2007 08:30 PM
ca drop bracket bamajeepjunkie XJ Cherokee Technical Forum 3 02-20-2005 12:26 PM
RE drop bracket install woes pissed me off today EricsXJ XJ Cherokee Technical Forum 6 04-13-2004 12:26 PM
