DRL module 1995 Cherokee Sport - JeepForum.com
post #1 of 8 Old 08-25-2009, 10:42 AM Thread Starter
trevor-m
1995 XJ Cherokee
My high-beams will not turn off even when jeep is turned off. I have been reading that it could be the daytime running lights module. Does anyone have a picture of it or know where abouts it is located/what it looks like?
trevor-m is offline
post #2 of 8 Old 09-04-2009, 09:45 AM Thread Starter
trevor-m
1995 XJ Cherokee
Anyone?? Thoughts??
trevor-m is offline
post #3 of 8 Old 09-04-2009, 09:48 AM
XJMuscle98
The lights will stay on a little bit if you turn them off after you turn the car off. Turn the ignition on, (no need to start it) turn the lights on and then off, and then turn the car off. See if they've gone off.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #4 of 8 Old 09-04-2009, 11:23 AM
Holder350
1995 XJ Cherokee
95 to my knowledge didnt have a running light module, it had an automatic light module to keep the lights on for about 2min after you turn the jeep off.
Like Matt said, try turning the key on and back off and see if they dont go out.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 8 Old 09-08-2009, 07:13 AM Thread Starter
trevor-m
1995 XJ Cherokee
Its a Canadian vehicle so they all of day time running lights. I will try the turn off thing, but something tells me it wont work.
trevor-m is offline
post #6 of 8 Old 09-09-2009, 08:23 AM Thread Starter
trevor-m
1995 XJ Cherokee
Found it after some trial and error. Its located beside the washer fluid reservoir attached to the side of engine compartment on passenger side. Small stand alone rectangular black box with one plug into it. Pulled it out and bingo, no more DRL's. Just have to remember to turn headlights on in day. Regular headlights seem to work although I dont think brights will.
trevor-m is offline
post #7 of 8 Old 12-26-2011, 10:42 PM
hoofbeat1
1995 XJ Cherokee
High beam headlights won't shut off.
I had the same issue this evening with my Canadian XJ. I pulled the DRL module plug and they shut off. The headlights now work when I turn them on and off. I lost the high beam indicator light in the dash cluster when I did this although the high and low beams work. The fog lights now work on high beam and low beam. I do like that part. Thanks for the info!
hoofbeat1 is offline
post #8 of 8 Old 07-14-2017, 02:00 PM
boddiebear
DRL issue here as well.
I have a 1999 Cherokee sport. I've replaced the headlight switch 5 times and still have this problem. When I pull the plunger switch all the way, the head lights come on. But the marker lights do not. If I push the plunger switch in a bit and find the "G" spot, I can get both to work at the same time. So I see there is a doorman part for a DRL but I can't seem to find my module. I hear its under the seat, behind the cigarette lighter, in the engine compartment, next to the parking brake, and the list goes on and on. I've spent a year researching this and still can't figure it out. I'm an electrician and I've even read the schematic which doesn't show a DRL... but they sell one for my models year, ect...! Anyone have some info that may shed some light into what the hell is going on with this rig? FYI one dealer says it's my interior control module, another said it's my light sensor on the dash. Can't seem to find an interior control module unless he meant the airbag module. And I don't see a bubble light sensor either. Would love to be able to drive my rig at night on the street again. Thanks guys.
boddiebear is offline
Hot wires 1995 Cherokee Sport 4.0 I-6 jonelsr XJ Cherokee Technical Forum 0 05-18-2008 11:10 AM
Where to find shift control module on '88 Cherokee? Woodtroll XJ Cherokee Technical Forum 4 09-21-2007 02:59 PM
1995 Jeep Cherokee Sport Inline 6 Magus2727 XJ Cherokee Technical Forum 14 03-28-2007 08:10 AM
Where is keyless entry module in '99 Sport? husker25 XJ Cherokee Technical Forum 1 06-14-2004 02:44 PM
Friend has a 1989 Cherokee bad ignition module XJ99 XJ Cherokee Technical Forum 4 06-02-2004 05:32 PM
