driving without rear driveshaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > driving without rear driveshaft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW!! HMF 50"-52" light bar mounting brackets!! Year End Clearance Sale! Save 20%
Unread 12-09-2014, 10:49 PM   #1
rizz
my u joint on my rear driveshaft busted and i removed the rear driveshaft. I am not sure what model transfer case I have but my model is an 01 xj sport. can I drive in 4h with my front driveshaft? will the transfer case fluid leak? and are there any potential concerns or issues with driving with just my front driveshaft in 4H.
and in regards to replacing the rear u joint, can I use a front driveshaft u joint for the rear driveshaft? if not whats the best place to quickly order or pick up a u joint?
rizz is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 11:11 PM   #2
Vassago
yes you can, but don't do it for long or at highway speeds
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f177/...lding-1575841/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 11:55 AM   #3
Motorcharge
I know more than you.
Motorcharge's Avatar
1991 MJ Comanche
Later XJ TCs are sealed and won't leak. Local parts stores should have ujoints in stock.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 01:37 PM   #4
rizz
Okay awesome thanks fellas
Unread 12-10-2014, 02:38 PM   #5
sAe23
1995 XJ Cherokee
I drove for a week or so once w/o causing any issues (that I know of...).
You can drive at highway speeds, just avoid jack rabbit starts.
sAe23 is offline   Reply With Quote Quick reply to this message
