Driving without rear drive shaft. - JeepForum.com
post #1 of 32 Old 12-15-2009, 11:56 PM Thread Starter
COLOUXJ
2010 JK Wrangler
I am trying to track down some vibrations i am having, i was wondering if i could drive in 4x4 without my rear driveshaft of dry roads, i know i am not supposed to with part time, but i am not sure how to check to see if my rear shaft is out of balance, i have already checked the front. So what is the word, would i be able to do it if all i have to make is right turns and some other slight turns?
COLOUXJ is offline
post #2 of 32 Old 12-16-2009, 12:03 AM
olds442
olds442's Avatar
you'll be fine
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #3 of 32 Old 12-16-2009, 12:04 AM
offroadnut36
1990 XJ Cherokee
x2 youll be fine
offroadnut36 is offline
post #4 of 32 Old 12-16-2009, 12:08 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
just go easy on it.
1990JEEPXJ is offline
post #5 of 32 Old 12-16-2009, 01:32 AM
Leo_1969
1991 XJ Cherokee
You can easily drive without the rear drive shaft - even part time 4LO on dry roads without a problem!
The only thing you must carry of is /depending on model of transfer case you have and which way do you remove rear drive shaft/ - you MUST somehow seal the rear extension opening in a transfer case to avoid oil leaking.
4.0 / NP231 / TrueTrac rear / BRC liquid gas equipment / Lift 3" / SkyJacker Nitro 8000 / Maxxis Bighorn MT-762 31x10.5 R15 / 13000 lbs behind original bumper :)
Leo_1969 is offline
post #6 of 32 Old 12-16-2009, 05:55 AM
multmigs
2003 WJ
I just did this for about a week due to bad U joints in my rear shaft, at first I was nervous but quickly realized there was nothing to fear. You can drive highway speeds etc, only thing noticible is very slow full lock turns...
multmigs is offline
post #7 of 32 Old 12-16-2009, 05:58 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Tape a 20OZ soda bottle to the rear tailcone when you do this.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 32 Old 12-16-2009, 05:59 AM
25jon25
well mine is a 93 and every time i have drove it without a shaft the think that connects my drive line to the T case falls out. causing the fluid to go. dont let that happen.
25jon25 is offline
post #9 of 32 Old 12-16-2009, 06:43 AM Thread Starter
COLOUXJ
2010 JK Wrangler
so what you guys are saying is that i need to secure the output shaft from the t-case? and i do have the 231 transfer case
reading the stock specs it seems like only pre 96 has the output that can come out.
COLOUXJ is offline
post #10 of 32 Old 12-16-2009, 07:59 AM
Leo_1969
1991 XJ Cherokee
Then this:
is a very good idea for you unless you have SYE installed
Leo_1969 is offline
post #11 of 32 Old 12-16-2009, 08:05 AM
Kettles
Then this:
He has an 01 thus a sealed TC and external slip yoke. No need to worry about anything spilling out.
You can drive it any wha you like in 4wd without the rear shaft, it will just be like driving a front wheel drive vehicle. The only reason 4x4 is a problem on dry roads is when the front and rear axles need to spin at different speeds.. but obviously without a rear shaft that is not a problem.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #12 of 32 Old 12-16-2009, 08:39 AM
bootht99
1990 XJ Cherokee
when my dad blew his rear end on his older f-250. he put it in 4 and drove from The Pas all the way down to Minnidosa, Manitoba. about a 7hr drive?
bootht99 is offline
post #13 of 32 Old 12-16-2009, 09:43 AM Thread Starter
COLOUXJ
2010 JK Wrangler
so all i need to do is remove the shaft and go for the test drive correct? i do not need to use the soda bottle?
COLOUXJ is offline
post #14 of 32 Old 12-16-2009, 09:46 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
you do not need to worry about fluid coming out
post #15 of 32 Old 12-16-2009, 10:07 AM Thread Starter
COLOUXJ
2010 JK Wrangler
ive got some questions about removing the rear shaft. I was reading the FSM is the rear shaft keyed or what are some pointers from you guys to remove the shaft?
COLOUXJ is offline
Quick driving without rear drive shaft Rollin XJ Cherokee Technical Forum 7 02-16-2009 10:42 AM
Driving w/o front drive shaft chadfrom610 XJ Cherokee Technical Forum 7 06-25-2008 08:02 PM
Rear drive shaft help GOKUSXJ XJ Cherokee Technical Forum 20 06-05-2008 09:22 PM
rear drive shaft 1996jeepgirl XJ Cherokee Technical Forum 5 12-30-2007 03:41 PM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 10:09 PM
