Driving with a RE 3.5" super ride lift...
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
I keep going back and forth between getting a lift kit, or not. So lets say I got the RE 3.5" super ride lift kit with the DT3000 shocks, or whatever the standard ones are for RE, and 31" tires. How much different would it drive, handle and acceleration than stock? Does anyone have this or a similar set up? Because right now, driving it stock, it's actually kind of fun to drive, probably to it being smaller. But if i got a lift and large tires, would I be all over the road, and have sluggish acceleration? Thanks guys,
Jordan
#2 |
Yes Man!
I have the super flex. Drives fine but i need new brakes. Thats about it. Slightly harder to stop and goes where i tell it to as far as the road goes at least. Might as well just get the super flex kit if your gonna life it IMO.
#3 |
what exactly is the difference. I was just kind of going with the super ride, because its my daily driver too
#4 |
Yes Man!
as far as i know just a lack of a super flex joint in the LCA, which would be a good idea to have if you went wheeling. Otherwise youd probably destroy the bushing. Mines my daily driver and the super flex rides great (for being lifted) Id say its pretty close to stock, minus the feeling of being higher off the ground.
#5 |
alright well thats good news
#6 |
if you are referring to how it will drive/steer/performance then yes it will effect all that. Steering will feel different, braking is reduced, acceleration is reduced as well as gas mileage with the tires that is
97 XJ D30/29 Sp. 8.25. Yukon 4.10's 4.5" Lift With Custom Long Arms w/ Chomoly heims IRO HD Tie Rod/IRO Adjustable Trac Bar 33x12.50x15 BFG AT's on 15x8 Soft 8's Warn TC Skid/Full 2.5" Exhaust w/ Dynomax Bullet |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
