Drivers side front wheel making awful squeaking/chirping sound... - JeepForum.com
post #1 of 11 Old 04-30-2012, 01:30 PM Thread Starter
Yojimbo
I need help diagnosing a sqealing/chirping shoud coming from the drivers side wheel on my 92 XJ Laredo.
At first I was thinking I just needed to swap out the hub/bearing assembly but after doing some research I found that it could be a number of things.
Before I spend a bunch of money on parts and tools does anyone have a good run down of things to check so I can determine the issue and fix the right thing?
Some background on this issue - I first noticed it after I had the drivers side sway bar link break. After I replaced the swaybar links I still kept hearing the sound. I did notice that the sound went away on a rainy day but came back after things dried up.
I have checked the serpentine belt and it does not appear to be the issue. The sounds starts at low speeds and seems to happen intermittently. It also seems to happen as I accelerate and sometimes goes away when I let go of the gas.
As I mentioned above it is coming from the driver side front wheel and makes a sqeaking/chirping sound like a very loud bird.
Any help will be much appreciated!
Yojimbo is offline
post #2 of 11 Old 04-30-2012, 01:48 PM
steelers1993
could be the hub, had too change mine out a year ago but mine never made any noise tho but im sure they can..id check the brakes(pads,brake disk)and if you put on a new hub look at the axle when you put it on.
steelers1993 is offline
post #3 of 11 Old 04-30-2012, 03:52 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Locate precisely the source of the noise. Unit/bearing hub, or axle u-joint, or drive shaft u-joint, or something else.
Google angry sparrows.
CJ7-Tim is offline
post #4 of 11 Old 04-30-2012, 09:41 PM
fordhartbreaker
Small chance it's the sway bar bushings mine were doin the same thing u just described 16 bucks and five mins later it went away
fordhartbreaker is offline
post #5 of 11 Old 05-02-2012, 05:12 AM
XJrauschic96
I'd say U-joint I had the same noise on bumps and turns
XJrauschic96 is offline
post #6 of 11 Old 05-02-2012, 05:23 AM
panamah_r3d
1993 XJ Cherokee
You can check if it's your hub/bearing assembly easily. Jack up the front end, grab the tire at the 12 o'clock and 6 o'clock position and see if you can wiggle the tire back and forth.
If it does it's more than likely your hub/bearing assembly. Mine made the same noise you're talking about when mine was bad.
Your brakes might get sloppy if it gets real bad, mine did at least but I also drove mine till the wheel damn near fell off ha.
1993 XJ 2 door - weekend warrior
1980 J10
2008 Evo X - DD
!don't hug that tree...I'm about to run it over!
panamah_r3d is offline
post #7 of 11 Old 05-04-2012, 01:03 AM
Ulver44
a rock stuck between dust shield and rotor can make that sound too
Ulver44 is offline
post #8 of 11 Old 05-04-2012, 07:09 AM
Pats94
U joint... my vote. Had the same thing happen, twice both times it was the u joint. Pita but easy enough and doesn't cost much.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #9 of 11 Old 06-18-2013, 05:08 PM
Naomi
Was wondering if u found the probelm. I just replace my caliper and drive shaft and the noise is still there and it doesnt do it in the rain.
Naomi is offline
post #10 of 11 Old 11-04-2014, 06:17 PM
monicat
chirping noise answer??
It's been a year and no one knows? I am suffering the same issue with my 04 TJ
monicat is offline
post #11 of 11 Old 11-05-2014, 04:55 AM
CJ7-Tim
CJ7-Tim's Avatar
Unless your Jeep is in their driveway, all anybody can do is give you a list of suggestions/possibilites for you to inspect for yourself.
CJ7-Tim is offline
ticking from front drivers side wheel need help tyler257 XJ Cherokee Technical Forum 4 04-17-2012 10:09 PM
Noise from drivers side front wheel solutionstt XJ Cherokee Technical Forum 4 07-11-2008 11:10 PM
Squeaking sound from front driver's side wheel/brakes insurrection151 XJ Cherokee Technical Forum 3 10-22-2007 11:49 AM
Chirping/squeaking in front end Jack Aubrey XJ Cherokee Technical Forum 4 09-30-2006 08:04 PM
Clicking sound from front drivers side wheel Rabindranath68 XJ Cherokee Technical Forum 13 06-02-2004 11:18 AM
