DRIVERS SIDE FLOOR PAN ROT - JeepForum.com
post #1 of 5 Old 03-26-2002, 09:17 PM Thread Starter
BUDMAN
Red face DRIVERS SIDE FLOOR PAN ROT
I JUST PURCHASED A 1991 CHEROKEE BRIARWOOD. IT HAS THE USUAL HIGH MILES (165K).WHILE CHECKING IT OUT, I NEVER NOTICED THAT THE THE FLOOR WAS ROTTED ON THE DRIVER SIDE.IT'S KIND OF TOUGH TO SEE IT BECAUSE IT IS ON THE INNER SIDE OF FRAME RAIL.WELL NOW THAT I HAVE SEEN IT ON A LIFT, I KNOW IT NEEDS IMEDIATE ATTENTION.SHOULD I JUST BRING IT TO A WELDING SHOP AND HAVE THEM FABRICATE SOMETHING OR IS THERE A PLACE TO BUY A REPLACEMENT FLOOR? RIGHT NOW THE HOLE IS ABOUT 2 INCHES ACROSS, BUT THE METAL AROUND IT IS IN POOR SHAPE(ABOUT A FOOT WORTH OF DAMAGE). THE REST OF THE JEEP IS IN VERY GOOD CONDITION EXCEPT FOR THAT SPOT. ANY SUGGESTIONS ON WHY THIS HAPPENS? <img border="0" title="" alt="[Eek!]" src="eek.gif" />
BUDMAN is offline
post #2 of 5 Old 03-27-2002, 01:00 AM
jeepcherokeev6
Post
do me a favor, press the button that says "caps lock"
Dan, San Bernardino, California
'86 XJ, 2.8 V6 5 spd, 3" lift
"It may be a piece of sh**, but its MY piece of sh**!" -Me
jeepcherokeev6 is offline
post #3 of 5 Old 03-28-2002, 09:48 AM
Kenny 96 XJ
Kenny 96 XJ's Avatar
Post
I bought a 93 in 1999. The floor was so rotten that it had a hole in it behind the passenger's seat right above the muffler! I noticed it after I crossed a water hazard for the first time because about 3" of water came in! To let it out, we made a bigger hole through the floor with only a plastic window scraper! And it didn't even show in the dealership's pre-buy inspection I had them do!
So After that I had the entire floor cut out and replaced (There is no replacement floor since it is a unbody, i.e. the floor is welded to the frame rails.), zinc coated and painted. And about a month after that I got into an accident and wrecked it! The worst dammage was to my Ego and pride I think!
Then I bought a 96 in 2000. The floor was also starting to rust. So I removed the entire floor carpeting, sanded the floor, plugged the small pin holes and will paint it soon. I'm now drivin it without a carpet... Since the bottom layer is a thick wool layer for heat and sound barrier that also acts as a big sponge and rust accelerator. There is a plastic tarp right above that layer so the water can't get in our out. Then there is the actual carpet you put your feet on.
Without all the carpeting, the truck is a little louder and especially warmer. But I have now access to the floor's drain plugs and can see how healthy it is...
96 XJ Sport having the 6 cyl engine as the ONLY factory option
4" custom lift, 31" Yokohama Geolandar A/T + II, Quick disconnects, no rear sway bar
Kenny 96 XJ is offline
post #4 of 5 Old 03-28-2002, 01:36 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
LOL, I feel lucky! My '96 has no rust anywhere in the floor yet. Is that a trait of Cherokees? Or does it happen to certain ones only as a flaw?
4wheeler4CJ is offline
post #5 of 5 Old 03-29-2002, 06:00 PM
TJs96XJ
Thumbs up
I have a 96 and 89 cherokee and neither have floor rust YET! Its just when i do go off-roading,or in the city snow and salt i keep it clean and heathly, it takes GOOD care of me and i take GOOD care of my babies.
"80" CJ7 Just sitting right now my son will be old enough soon to help with his jeep
"87" Cherokee
"89" Cherokee Mud-dog
"96" Cherokee Country 3.5 RE Lift IT REALLY IS A JEEP THING!!!!!!! $3,100 wish list down from $4,600 God made earth in 6 days and went WHEELINNG on the 7th
TJs96XJ is offline
If your drivers floor get wet after rain, I think know why themow XJ Cherokee Technical Forum 21 01-12-2011 06:04 AM
Vibe under drivers side floor boad wjp XJ Cherokee Technical Forum 1 01-10-2008 06:55 PM
Drivers Side Window.. XJRookie XJ Cherokee Technical Forum 3 11-06-2007 11:35 AM
Wires Running Accross Drivers Floor snowblur17 XJ Cherokee Technical Forum 3 11-13-2005 03:35 PM
Clunk under drivers side beaver24 XJ Cherokee Technical Forum 11 02-01-2005 06:05 AM
