Drivers Door Latch Picture? or Diagram? - JeepForum.com
post #1 of 4 Old 01-26-2005, 05:43 PM Thread Starter
Scrub
Scrub's Avatar
2012 KK Liberty
Ok well my drivers door doesnet open from the inside, only from the outside and its kind of a pain to hafta roll down the window everytime i need to get out.
The Problem is that the Linkage from the Handle to the latch wasent connected, and the little plastic clip was gone also, so i got another clip while i was at the jy, but i dident happen to look at which little arm the linkage connects too there are a few different ones.
Does anyone have any pictures of the latch with the linkage connected to it, im trying to not have too pull the passenger side door apart right now in the rain.
thanks
-Matt-
89 XJ 4door - Limited - AW4 - NP231 - 180K - 31's - About 5" Lift - Trimmed - GONE!
2012 Jeep KK Liberty Sport - Stock for now
Scrub is offline
post #2 of 4 Old 01-26-2005, 06:17 PM
Islandroaddie96
Islandroaddie96's Avatar
There are two rods and only two rods. The one for the lock button has the end that points upwards and the the door latch points downwards. They do cross each other in about the middle of the door panel, so keep that in mind. If the rod fell to the bottom of the door, you simply push it back up and you can feel it sorta pop back into the place it should be. There is no other trick to it. Put the rod through the hole on the door handle, and pop the clip back into place and you are done.
Good Luck,
Peter
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline
post #3 of 4 Old 01-26-2005, 06:27 PM Thread Starter
Scrub
Scrub's Avatar
2012 KK Liberty
there are a few little places in there that it could hook onto, and the clip was just gone, and it did fall to the bottom, but i dont know which hole to intall the clip then the rod into.
Scrub is offline
post #4 of 4 Old 01-26-2005, 06:51 PM Thread Starter
Scrub
Scrub's Avatar
2012 KK Liberty
ok i figured it out, the arm that the rod hooks too had fallen back right against the latch, and i couldent see it at the time that i was looking but i got it hooked up now, thanks for the help
-Matt-
Scrub is offline
vacuum diagram/picture murray00 XJ Cherokee Technical Forum 3 01-10-2010 09:45 PM
95 cherokee drivers side hood latch is stuck dirtyjeepgirl69 XJ Cherokee Technical Forum 0 12-16-2009 05:41 PM
inside door latch wont open door! baba1 XJ Cherokee Technical Forum 2 03-17-2009 09:31 PM
Help! Door Latch - Inoperable.....door locked-shut!! izmichael XJ Cherokee Technical Forum 7 03-14-2007 05:17 PM
Outside Drivers Front Door Latch XJae XJ Cherokee Technical Forum 1 06-22-2005 07:13 PM
