Quantcast driver side front brake rotor problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > driver side front brake rotor problem
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 04-15-2009, 06:45 PM   #1
mhall101
mhall101's Avatar
i just tried 6 differnt rotors (new) and i cant seem to find on to fit.... they are all too thin in the flange so they rub on the dust cover cuz they go on too far.... the jeep was used and i dont know the history of it, could some one have switch spindals?? i dont want to build a spacer cuz i wont have many thread left... any one had a problem like this???
Originally Posted by 99xjjoe
"when i get in and turn the key the coolness goes through the roof"
mhall101 is offline   Reply With Quote
Old 04-15-2009, 08:04 PM   #2
LeftOfCenterXJ
1988 XJ Cherokee
Maybe just bend the dust plate out of the way if it's possible?
IDK for sure about different knuckles, I think I read on here about there being different rotors for different years. Maybe somebody swapped in an older axle with the old style rotors.
"Too weird to live, too rare to die"
2000 XJ Silver, 3", 31's DD
88 XJ Blue, 4.5", 33's, Project Build Thread
Originally Posted by Juju
It makes your trolling more credible to be grammatically correct. Lets everyone know you're a legitimate troll, not just one of those poser trolls.
LeftOfCenterXJ is offline   Reply With Quote
Old 04-15-2009, 08:06 PM   #3
mhall101
mhall101's Avatar
hey thanks thats a start... any one else know info?
Old 04-15-2009, 08:58 PM   #4
JeepRide
Anything is possible wheel bearings could have changed to older 95 and back also there is a couple different rotor size's their is 1\8 difference in the height of the two.Did you take rotor to the store and try to match one up.
98 xj 4.0L 231 t\case off road commode
4 in the floor and a fifth under the seat
Eat more possum
JeepRide is offline   Reply With Quote
Old 04-15-2009, 10:45 PM   #5
filluptrk
Could you see if your parts people would give you the different rotors from the earlier years to try. You won't have to bolt them up just put them on and find the one that works. They will be returnable since they are only used to find correct ones. Just a thought. Phil
filluptrk is offline   Reply With Quote
Old 04-15-2009, 11:55 PM   #6
LeftOfCenterXJ
1988 XJ Cherokee
you could also break out a micrometer and do some measurin'!!! The parts guys would definately let you do that.
Old 04-16-2009, 06:13 AM   #7
jontz
1995 XJ Cherokee
They gave you the wrong year rotors. Some older years of front rotors are deeper, and when bolted on to a newer jeep they won't fit. To double check, lay the rotors on top of each other 69 style, and see if the hat of the new one is about 1/8" - 1/4" taller than the old one you took off.
Originally Posted by BunnyHunterOG View Post
i feel like i didnt deserve it, but still had a seizure
jontz is offline   Reply With Quote
Old 04-16-2009, 08:56 AM   #8
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Use the Tech and FAQ's - http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/
Read the one about Hubs and Rotors - http://www.jeepforum.com/forum/showthread.php?t=360959
Visually compare your unit hubs and confirm they are both the same style. It is possible you have one 1999 or older hub and one 1999.5 and newer hub.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 04-18-2009, 12:12 PM   #9
mhall101
mhall101's Avatar
from my measurments the old rotor (one that works) is about .375'' shallower then the new ones that dont fit... i just ordered one from a 01 xj cuz its a different part # so i hope it will work!!!
Old 04-20-2009, 07:06 PM   #10
mhall101
mhall101's Avatar
yup the 01 xj brake rotor worked so the prev owner must have put a different spindal on..... its all good now thank you
Old 04-20-2009, 10:41 PM   #11
98junk
Nice 2 door.
98junk is offline   Reply With Quote
Glock Forum
