Driver seat front mounting location repair - JeepForum.com
post #1 of 12 Old 03-19-2017, 07:33 PM Thread Starter
LogicViking
Ok guys, I've had a water leak in the drivers floor for a couple week, pulled all my interior to check it out and found some rust issues. Apparently the PO had pulled the driver seat for what I assume was rust, and welded new brackets on the seat..
Anyways, the crossmember that mounts to the floor pan that takes the front two bolts for the seat is rusted to pieces. Have any of you found a way to repair an existing one with this much damage, or should I replace it? If so, can anyone link me to a part source? Any way I can avoid welding would be great, but i know I might not have a choice.
Thanks y'all!
Sent from my iPhone using Tapatalk
LogicViking is offline
post #2 of 12 Old 03-19-2017, 07:42 PM
festerw
festerw's Avatar
I don't have a picture but when I replaced the floor pan in mine I used a piece of 1/8" flat stock to bolt the seat to, cut 4 triangle braces to go along the back, and welded it to the floor and sides.
festerw is online now
post #3 of 12 Old 03-19-2017, 07:52 PM Thread Starter
LogicViking
Thanks for the quick reply!
That may be the route I have to go down, I'm not finding any kind of replacement parts.
post #4 of 12 Old 03-19-2017, 08:36 PM
HEAP_of_JEEP
When I did my floors, I had to fabricate a new seat bracket out of 1/8" steel.
Check us out on Youtube
HEAP_of_JEEP is offline
post #5 of 12 Old 03-20-2017, 04:11 AM Thread Starter
LogicViking
That seems to be the consensus, haha. Thank you very much!
post #6 of 12 Old 03-20-2017, 04:40 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
That floor mount is beyond repair. A few years back when I fixed my floors, I ordered that part from the Dealership. Some square tube or angle iron welded to the floor would be an adequate substitute.
CJ7-Tim is offline
post #7 of 12 Old 03-20-2017, 04:41 AM Thread Starter
LogicViking
Awesome, do you happen to have the correct name or part number still?
post #8 of 12 Old 03-20-2017, 04:55 AM
festerw
festerw's Avatar
Part number is 55174759AB, it's discontinued which is why I ended up making my own.
post #9 of 12 Old 03-20-2017, 05:57 AM Thread Starter
LogicViking
Thank you for the information. I really appreciate all the help!
post #10 of 12 Old 03-23-2017, 04:54 PM
bluejunior
bluejunior's Avatar
I looked for replacements for ages before replacing my floor panels. Just make the bracket, no one makes replacements anymore and the warehouses have been emptied of the leftovers.
The only other thing you could do is try to find a set in better shape on a JY XJ and cut them off and weld them on yours, frankly I think the 1/8" and brackets will be a better solution and about the same effort.
Lifted, Locked, Stiffened
bluejunior is offline
post #11 of 12 Old 03-23-2017, 05:43 PM
KF4SQB
1994 XJ Cherokee
Just keep in mind if you decide to "roll your own" seat brackets: if they fail in a crash, you could be very seriously injured! Make sure that you make them adequate to "hold the load". A good rule of thumb for "crash force" is to multiply the weight of an object by the speed of impact. For example, say that you weigh 100 pounds (easy number to work with). In a crash at 30 MPH, you would weigh the equivalent of 300 pounds. At 60, 600 pounds. Make sure that your "engineering" is up to the task!
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #12 of 12 Old 03-23-2017, 06:45 PM Thread Starter
LogicViking
I appreciate the tips guys, I've got a guy fabricating me a new one, I would rather do everything myself but as it was pointed out that's a possible safety hazard. Sometimes gotta leave it to the pros!
