Driver Door stuck??? - JeepForum.com
post #1 of 14 Old 12-17-2007, 09:15 PM Thread Starter
89mudlite
2015 JK Wrangler
im new here but i really need some help on this one...back in the early summer my inside latch to the driver door stopped working so i'd have to open the door from the outside not really a problem...but one day i unlocked the door as i pushed the outside handle in and bam the door wouldnt work and hasnt worked since then...im sure the door handles are busted but i still cant get this door opened...i really have no idea on how to get it open at all...any idea's at all please help im sellin my car and going back to drivin the 89 as a daily driver...when u have to crawl in from the passenger side everytime it really makes for a pain in the butt...all idea's would be appreciated thanks guys
1989 Cherokee 4.0 4door 4wd 3" rc aal kit, c8.25, custum front bumper, cragar v-5's and 32x11.50 bfg mt's
89mudlite is offline
post #2 of 14 Old 12-19-2007, 08:20 PM Thread Starter
89mudlite
2015 JK Wrangler
still havent figured this thing out...i really dont wanna take it to a local shop and pay 60-80 dollars an hour when i could do it myself plus i hate paying someone to do something i can do...thanks people
post #3 of 14 Old 12-19-2007, 09:15 PM
Shoobie
1989 XJ Cherokee
If you can roll the window down, maybe you use a thin metal rod to move the linkages from inside the door (kind of like when you lock your keys inside). Probably not the easiest thing, but it's all I can think of.
Shoobie is offline
post #4 of 14 Old 12-19-2007, 09:34 PM Thread Starter
89mudlite
2015 JK Wrangler
i have tried messin with the linkage on the inside bc i have the door panel off and still cant seem to get n e thing workin...its one mess...when or if i get the door off i can jus go doorless or buy another but until then im screwed
post #5 of 14 Old 12-19-2007, 10:04 PM
Shoobie
1989 XJ Cherokee
If you have the panel off, you should definitely be able to open it. Find the rod that actuates the latch, and push on it. I've never looked inside an XJ door, but I've done it like this on several other vehicles.
Shoobie is offline
post #6 of 14 Old 12-24-2007, 10:24 PM Thread Starter
89mudlite
2015 JK Wrangler
actually i couldnt get it open with the panel off...but with some thinking i took the rear door off and took a recip saw and cut the striker plate off door opened...after 7 months of being stuck i took the lock mechanism out and still not a budge...but i was wandering if i could take the lock mechanism off the back door and use it any suggestions?
post #7 of 14 Old 12-25-2007, 09:37 PM
ar275103
1993 XJ Cherokee
encountered the same prob in my 93 xj, turned out the pin that controls the door lock was broken. Had to take off the panel and with a screwdriver and flashlight closely examine the passenger door to see how it operated. i was able to use a screwdriver and pry on the inside of the latch part that controlled the door lock while working the handle. hard to explain but very easy to fix. Replaced the whole latch assembly with a new junkyard unit
ar275103 is offline
post #8 of 14 Old 12-25-2007, 09:53 PM Thread Starter
89mudlite
2015 JK Wrangler
yea man now i gotta go buy a new striker plate but i was wandering if the lock assembly from the back door would work im thinking it prolly wont...how much of a PITA was it to put the new one in and how much did it cost...i need to post some pics showing what i did...
post #9 of 14 Old 12-26-2007, 10:55 AM Thread Starter
89mudlite
2015 JK Wrangler
went to the junkyard found a nice 89 jeep down there they took the latch assemby off for me 40 dollars for it all i found it to be pretty cheap since the stealership wanted 90+ for it...as for puttin the new one in i have no idea...also thinkin bout doin the gauge swap...50 for the gauges is that a bad price?
post #10 of 14 Old 12-26-2007, 07:11 PM
600buckXJ
1995 XJ Cherokee
I just had a similar problem with my '95. My problem ended up being that the latch still worked fine, but it would not unlock. So it just acted like my door was locked all the time. I replaced it with a latch off of a parts Jeep. (I practically have my own junkyard!) The latch assembly out of the rear doors appear to be the same, but you would not have had a good way of latching the rear door then.
The most difficult part of replacing the latch is unhooking and rehooking the door handle and lock rods. Try to be patient, have a small bright flashlight, and maybe some various size/shaped pliers. That should make things go more smoothly. Also, lubricate the new latch thoroughly as well as everything in the door when you're done! That will help you in the long run.
Current: Red, 1995 XJ, 4dr, 201,000 miles on 4.0L HO, AW4, Command trac, w/AC. See profile for current mods.
RIP:(The 600 buck XJ) 1987 XJ, 4dr, 211,000 miles on 2.5L 5spd, command trac, w/AC.
600buckXJ is offline
post #11 of 14 Old 12-26-2007, 09:14 PM Thread Starter
89mudlite
2015 JK Wrangler
thanks man i appreciate the help and as for puttin the latch back in...i tried earlier it is a PITA but ima get to it tomorow with the help of another buddy...hopefully we can get this bak in...today i spent 5 or 6 hours wrenchin on various small things to get it runnin in tip top shape...hopefully by spring ill have it where i want it
post #12 of 14 Old 12-27-2007, 09:42 PM Thread Starter
89mudlite
2015 JK Wrangler
got the latch assembly in..thanks for the replies...door works great jus wish i could say the same for alot of other things on the jeep...but hey its a jeep...i wouldnt have n e thing to do if stuff didnt break so frequently
post #13 of 14 Old 12-27-2007, 10:11 PM
cajunbull61
I paid 20 for mine at Pullapart. Check their site... 3 locations in Ky. Cheeep prices. pullapart.com
cajunbull61 is offline
post #14 of 14 Old 12-27-2007, 10:45 PM Thread Starter
89mudlite
2015 JK Wrangler
eh well it costs me 20-30 dollars in gas to get to the nearest one i only see one in kentucky...so ill prolly end up drivin 5 mins down the road and have them pull the part for me...plus their gonna give me the oil pressure sending unit and the coolant sending unit for an extra 10 bucks...cant beat that...and they pull it...thanks for the idea tho
Door latch stuck and door won't close now.... PUNISHER_VETTE XJ Cherokee Technical Forum 11 05-09-2016 06:08 AM
Driver Door Lock viper719 XJ Cherokee Technical Forum 7 01-26-2009 06:23 PM
Driver Door Check Arm bajafanatic XJ Cherokee Technical Forum 2 05-04-2008 08:44 AM
Driver door stuck closed ar275103 XJ Cherokee Technical Forum 1 06-20-2007 01:29 PM
Driver Door won't Lock awightaz XJ Cherokee Technical Forum 3 03-20-2006 08:55 AM
