Drive it into the dirt until it dies, fix it, and drive some more!!
#1 | |
I'm trying to figure out what to do with my aging Cherokee. It has 200,000 miles on it and I've decided to make it a trail rig... ok, a trail beater
I first thought I'd lift it, upgrade the axles, etc. but quickly realized I'd spend more on parts than the entire truck is worth. Then I thought I'd purchase a used Jeep already lifted, but then what is the point of keeping the one I have?!? In the end, I think I'm now leaning towards making very little changes and just driving it until it breaks, fix it, and drive it some more. I'll be happy to get out on the trail once a month, doing some medium level off-roading. My Jeep has never failed me before, so it should be able to hold up to some abuse without having to do any major upgrades... right? With that in mind, my leaf springs are weak and cause the truck to sag. I friend mentioned getting either stiffer coil springs, or lower shackles and new leaf springs which should give me 1" - 2" of lift. What low cost fix would you recommend to improve my sagging suspension? AAL? Stiffer Coils? Lower shackles? Other ideas? Thanks for the help and ideas...
#2 |
The Guru of Nothing
just grab some new leafs and coils, maybe find some in a JY. if this truck is going to be a beater no sence in throwing money at it if your just going to drive it into the ground.
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#3 |
what condition is your jeep in now? (lift/mods etc.......) also axles do you got the 8.25 or the D35?
if you got a D35 you can go to 32 or 33's tires and if you got the 8.25 you can go up to 35's (but I would not recommend it because the gearing would suck and new gears cost $$ ) also is it an auto or manual? I say just do enough lift to clear 33's hack the fenders get a few skid plates, and make sure yougot a recovery point and wheel the HELL out of it!
98 XJ SE 4.0 L White 70,xxx miles RE 3.5in Super Flex Lift, BFG AT 32x11.5x15; adj Control arm, RE gen2 disco's, T-case drop
Factory Front Skid/ TC Skid/ Gas Skid; Cobra 18 WX ST II SoundTracker CB 3 FT firestick mounted on RoofRack; Set of BaJa lights top bumper mounted; Light bar/w 150watt KC DayLighters ;Rusty's Air intake; FM Delta 50 C 4X4 front tow hooks; Rear Hatch Speakers; Painted Fenders Flares; herculined floor; Back-Up lights inside bumper My car Domain Page |
#4 |
Stock form now. '93 Cherokee 4-door Sport auto.
Not sure which axles... how do I find out? |
#5 |
Trim the heck outta it and add a BB (100 dollars)
then put on 33's...i think there is a pic of one next to Erics (EricsXJ) and the trip they were on it was amazing...it has NO lift too also, HeavyMetal did a job like that and it looks awesome and real capable
87 XJ pioneer-Totalled 96 XJ Sport- Sold Now: 88 RENIX 4.0 XJ, Project Overlander 3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats |
#6 | |
#7 | |||
Thanks for the help!! |
#8 | |
I would look into new (or newer used) rear springs and putting a budget boost on. Cheap and easy. |
#9 |
Any good suggestions for a cheap budget boost? What do I buy?
#10 |
Here's what I would do if you are going for cheap:
Get a used 2" spacer for the front, or go to the junkyard and get a few stock coil isolators for each side. For the rear get two newer sets of xj leafs. Combine both sets into a bastard pack. You'll have to mix and match to get the desired lift height. After you lift it you will have to deal with a couple of other things: shock length, brake lines, alignment, and possibly vibes. Make some bar pin eliminators (bpe's) for the shocks. This is basically free if you have a grinder, drill, and some angle iron. Search for some write ups on it. Relocate the rear brake line. Hack off the rear brake line support, bend the line down, and attach the support with a strip of metal so it doesn't bounce around after bumps. The front lines will be long enough in stock form for just a 2" lift. You can do a drive way alignment with basic tools. Search for it, there are plenty of write ups. If you do get vibes (unlikely, especially if it is older than 96) just do a home made t-case drop. After you do all of this trim your fenders, throw some 31s on and wheel it. |
#11 |
Since it's a beater, just put some spacers on the front coils and blocks in the back. 3" blocks from autozone for $15 and I'm sure you can find the spacers for under $30, decent budget lift.
#12 | |
I would have to say stay away from block and shackles, only because he is running a stock setup up and his rear leafs are sagging and block and shackles will only make that worse.
#13 |
nom nom nom
If you plan on staying in the world of Cherokees, even after this one completely dies, I'd suggest getting a good quality suspension. You can always swap the good parts out of the dead Jeep into a fresh one.
I originally planned to do this with my '93 but she just keeps on going. I suspect that the XJ is going to outlast my aftermarket parts.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount '97 Cherokee Sport 5spd,231, white, stock '90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc. '87 XJ 2" lift '96 XJ stock "Personally, I've learned so much from my mistakes, I'm thinking of making some more." "Don't believe everything you think..." |
#14 | |
Thanks for all the great info/ideas!! |
#15 | |
![]() ![]() ![]() ![]() just kidding, spend $200 on new aftermarket lift leafs, you will be happy you did. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
