DRB II scan tool - JeepForum.com
post #1 of 7 Old 05-01-2002, 08:41 PM Thread Starter
juan
Post DRB II scan tool
Have any of you people have used a drbII scan tool?
I have the chilton repair manual and it says that in 1990 and earlier models this tool is needed to get the trouble codes from the ecu.
I cant find this tool in any place in the internet.
juan is offline
post #2 of 7 Old 05-03-2002, 12:02 PM
kbeckman
kbeckman's Avatar
Post
Try this:
<a href="http://www.zjilla.com/tech_codes.htm" target="_blank">http://www.zjilla.com/tech_codes.htm</a>
Prior to 1998 (I think) you can get the error codes as blink codes out of the "check Engine" light. I assume this works on a 1990 Jeep as well....
kbeckman is offline
post #3 of 7 Old 11-26-2009, 04:47 PM
Shandley
1990 MJ Comanche
For those who are wondering, a 1990 Jeep will require a DRB-II. No amount of playing with the ignition ON-Off-ON-Off-ON will not get codes.
1991 started with the OBD-I
1984-1986 V6 can do the ignition thing to get the codes.
Thanks,
Shandley
Shandley is offline
post #4 of 7 Old 11-27-2009, 04:00 PM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
I have a DRBII in my garage, you will also need the Jeep Eagle adapter for the DRBII in order to diagnose the 87-90 jeeps. There are no codes either, it only does live time data display.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
post #5 of 7 Old 03-01-2016, 12:23 PM
lunzy
1987 YJ Wrangler
Do you need the Jeep Eagle adapter with the DRB II for a 94 Jeep Wrangler? I have an 87 upgraded with he MPI kit which is supposed to now meet 94 emissions and service requirements.
lunzy is offline
post #6 of 7 Old 03-09-2016, 07:41 PM
MunkMaster
the DRB scan tools are factory scan tools. they have since moved onto a completely different system but to do most of the stuff on the cherokees you need the drb system.
MunkMaster is offline
post #7 of 7 Old 03-14-2016, 08:04 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No codes. Only live data as stated. I have the factory tool with the adapters. What are you trying to do?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
Scan tool xjdavid1 XJ Cherokee Technical Forum 5 10-09-2009 03:15 PM
What is DRB scan tool? electriczipper XJ Cherokee Technical Forum 9 02-23-2009 07:54 PM
PC scan tool software SilverXJ XJ Cherokee Technical Forum 0 03-25-2008 07:03 PM
Scan Tool Moekin XJ Cherokee Technical Forum 14 01-16-2008 01:28 PM
98 XJ OBD II scan tool netrnr XJ Cherokee Technical Forum 4 06-03-2005 10:31 PM
