Double Check Me please - JeepForum.com
post #1 of 9 Old 09-27-2010, 03:59 PM Thread Starter
Lifesgoodhere
Ok inspection....t - 3 days.
I was doing a quick pre-inspection today and noticed my front right (FR) turn signal bulb was out. It the parking light still lights up, so it must be the 2nd filament right?
Replaced the bulb with a new one. Still no signal light. the rear right (RR) lights up however.
Checked with my ohm meter the socket, one dead. Ok so that meas I have a short between the switch and the light correct?
before I tear into the signal column what else could I have skipped over?
A Jeeper for life
Lifesgoodhere is offline
post #2 of 9 Old 09-27-2010, 04:07 PM
AequitasVeritas
AequitasVeritas's Avatar
Relay perhaps?
1998 XJ - "El Jefe" 4.0L | Superlift | Dunlop | Cragar | Bushwacker | Hypertech | OR-Fab | Hi-Lift | Pilot | Smitybilt |
AequitasVeritas is offline
post #3 of 9 Old 09-27-2010, 04:15 PM
AequitasVeritas
Or maybe the fuse?
post #4 of 9 Old 09-27-2010, 05:38 PM Thread Starter
Lifesgoodhere
checked the fuse, all my other lights are working though. But I did notice someone had been in that light before, butt connectors
Haven't checked the relay yet.....where is it?
A Jeeper for life
post #5 of 9 Old 09-27-2010, 06:00 PM
Diamond-x
1991 XJ Cherokee
Right under the stock airbox there is a conenctor that may be the source of your trouble. I think it is the main connection of the front lights to the wiring harness. The connector holds moisture due to it's location under the airbox, and many I've seen we're severely corroded. My first XJ was so badly corroded that I ended up splicing out the connector, bypassing and removing it. This solved my problems with front blinkers and headlights.
Your troubles may be elsewhere but it couldn't hurt to take a quick look, remove your airbox and open the connector to see the possible carnage.
I hope this helps.
Diamond-x is offline
post #6 of 9 Old 09-27-2010, 07:02 PM Thread Starter
Lifesgoodhere
good thinking I will look at that tomorrow, but when I took the airbox out to clean it and fix a power steering line I didn't see such said connector. The signal light in the dash works, and isn't the RR and the RF connected? but the RR signal light works...... wouldn't be a simple flasher would it?
A Jeeper for life
post #7 of 9 Old 09-28-2010, 09:01 AM
AequitasVeritas
Not sure where the relay is. But seems like there is an under hood relay box on the drivers side.
post #8 of 9 Old 09-28-2010, 11:23 AM
Greenz
Bingo...
Check for a bad connection there even if you have to replace all the butt connectors. Many diy crimp terminals fail due to improper installation. There are tons of substandard crimp tools sold. One should really invest in quality strippers and crimpers like Klien. Don't forget to protect the connection with shrink tube.
More likely to have an open circuit rather than a short. A shorted circuit would cause more symptoms like blown fuses, burnt wiring, or more lights out.
Greenz is online now
post #9 of 9 Old 09-28-2010, 05:48 PM Thread Starter
Lifesgoodhere
I re did them today and made it up to the inspection station it passed, but the fuse blew (for the turn signals) while we were checking the turn signals.
A Jeeper for life
parking light , turn signal
check engine light on 2000 cherokee.. can i check it my self? Magic2979 XJ Cherokee Technical Forum 27 12-11-2013 08:46 AM
Double Check My plumbing THISISWEIRD XJ Cherokee Technical Forum 2 04-06-2009 07:46 AM
Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo darkstarpa XJ Cherokee Technical Forum 2 09-17-2006 06:24 PM
Double check with me please.... Brake Install.. RickyN29 XJ Cherokee Technical Forum 10 03-20-2006 12:11 PM
Double check on CAT part # Shaggyz98XJ XJ Cherokee Technical Forum 10 10-25-2004 09:00 PM
