#1 | |
Doorless....
Well I chopped the bottom of my hinges off today and took the drivers side door off, it was pretty cool until I tried to put it back on...
getting the pins to line up with the hinges was more or less impossible and we ended up unbolting the hinges from the door, putting em on the mounts on the body, and bolt the door back on. Is there some trick im missing or is it just a royal pain in the *** to get the doors back on?
92 YJ, 35's, 6" 97 Honda CBR1100xx |
#2 |
Mine slide in an out like butter.
Use either a disk grinder or some course sand paper and take some metal off of pins to drop the OD a couple thousands. Get some DW40 or Break Free CLP, lube em up and drop them in. That is what I did and it works great. |
#3 | |
the pins slide in and out fine when theyre off the door, but its more getting the door at the right angle to slide em in thats the pain in the arse.
#4 |
The length of your pin may also be the culprit. The pin on my doors are just slightlly stick out of the middle hinge when they are in.
#5 |
Forum God
its just something u have to get the hang of, lining up the angle that is. it can be really hard at first, hell ive done it countless times and every now and again i find myself struggling to line it up, doesnt help they weigh 5993384 pounds and u have to line them up just right lol
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
#6 |
easy fix is to cut the bottom pin 1/4 of an inch shorter than the top..... this was you can line up the top one in the hole... then pop the second one in with easy.... just helps so you odnt have to line them both up at the same time....
#7 | |
Forum God
#8 | |
tell me about it espesually since i have the huge *** 2 door doors and my drivers side has 2 difrent hinges ![]()
92 Cherokee Trail toy. - 97 Cherokee Street toy. XJcruiser: Crumple zones? I guess the other car will have to share those. |
#9 |
make sure you lined the hinges back up where the factory had them and also make that hole alltile bigger and you should be mint.
#10 |
yeah ive gotta enlarge my holes too..my 2dr doors are madly sagging...=-[
[URL="http://www.myspace.com/gatmog"]xj video on my myspace page[/URL] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
