Door won't unlock/lock w. keyless - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Door won't unlock/lock w. keyless
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 12-01-2012, 09:10 AM   #1
mhjo
The drivers door wont unlock/lock with remote.
I can lock/unlock with key, but in it remains in last position when I push remote. It gives a "click" inside the door, but nothing happens. All other doors are fine.
What shall I do?
1996 4.0 Country, K/N, MSD ignition, Dynomax VT, 63mm TB
mhjo is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 10:18 AM   #2
buildin1XJ
Wil it lock or unlock with the electric switch inside the door?If not the rod that connects the lock actuator/motor has probably come loose.
buildin1XJ is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 10:40 AM   #3
PhotoJared
Or the rods need to be tweaked to fit a little. I have the same problem in my '99. I cant lock the driver door with the electrics.
'99 XJ Sport
RE 3.5"
31s
other stuff
PhotoJared is online now   Reply With Quote Quick reply to this message
Unread 12-01-2012, 11:12 AM   #4
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Clean and lubricate the lock cylinder, locking mechanism and door latch mechanism. Use Throttle Body cleaner and a light oil such BreakFree CLP gun oil.
If the problem remains after clean/lube, make sure the lock solenoid is getting full voltage and has a solid ground. As suggested also make sure the lock rods are properly installed and are correctly aligned.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
