Door won't unlock/lock w. keyless - JeepForum.com
post #1 of 4 Old 12-01-2012, 09:10 AM Thread Starter
mhjo
The drivers door wont unlock/lock with remote.
I can lock/unlock with key, but in it remains in last position when I push remote. It gives a "click" inside the door, but nothing happens. All other doors are fine.
What shall I do?
1996 4.0 Country, K/N, MSD ignition, Dynomax VT, 63mm TB
mhjo is offline
post #2 of 4 Old 12-01-2012, 10:18 AM
buildin1XJ
Wil it lock or unlock with the electric switch inside the door?If not the rod that connects the lock actuator/motor has probably come loose.
buildin1XJ is offline
post #3 of 4 Old 12-01-2012, 10:40 AM
PhotoJared
Or the rods need to be tweaked to fit a little. I have the same problem in my '99. I cant lock the driver door with the electrics.
'99 XJ Sport
It has a lift
It has 31's
It also other stuff
PhotoJared is offline
post #4 of 4 Old 12-01-2012, 11:12 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Clean and lubricate the lock cylinder, locking mechanism and door latch mechanism. Use Throttle Body cleaner and a light oil such BreakFree CLP gun oil.
If the problem remains after clean/lube, make sure the lock solenoid is getting full voltage and has a solid ground. As suggested also make sure the lock rods are properly installed and are correctly aligned.
CJ7-Tim is offline
