Door Panel Problem - JeepForum.com
post #1 of 5 Old 06-28-2012, 12:56 AM Thread Starter
rkirbyaz
Door Panel Problem
About a year ago I had some kids in the back of my 96 XJ. The locks are a little sticky and they didn't have the door unlocked. When they tried to open the door, it wouldn't - because it was locked. So they started yanking on the door lever trying to open it. Something shaped and now the lock and the lever don't work. I'm pretty sure I can fix it, once I get into the door panel. My problem is I need to get the door open to remove the panel. To open the door I need to get it unlocked. To get it unlocked I need to fix it. To fix it I need to get the panel off. And round and round we go. I am tired of having a 3 door Jeep. Any advice would be greatly appreciated.
rkirbyaz is offline
post #2 of 5 Old 06-28-2012, 07:51 AM
muaddib420
Get a locksmith to shim the door open.
muaddib420 is offline
post #3 of 5 Old 06-28-2012, 06:06 PM
keepishop
1989 XJ Cherokee
You may be able to remove the panel after removing the rear bench seat. After the panel is off you should be able to open the door by yanking whatever little metal arms and levers in there that you can get your hands on.
If you spray white lithium grease on all of the moving bits it will probably make your power locks work better. I ******d mine out with wd40 as a quickfix, and the next day they were totally dead. Redouching with white lithium grease spray totally brought them back. This was after doing the kickpanel relay fix, so don't assume relays are a cure all for sticky mechanisms.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #4 of 5 Old 06-29-2012, 10:31 AM Thread Starter
rkirbyaz
Thanks, that work with only insignificant damage to the panel.
rkirbyaz is offline
post #5 of 5 Old 07-01-2012, 05:33 PM
keepishop
1989 XJ Cherokee
I wish it would work on my cousin's stupid maxima's stuck door. Still looking for a technique to get that bastard open.
Bleed or Quit.
broken , door , lock , panel
ARG! Interior door panel off, door shut. mukota XJ Cherokee Technical Forum 3 06-21-2011 09:07 AM
Door panel JBXdudeTJ XJ Cherokee Technical Forum 2 08-10-2006 09:02 PM
Door panel removal problem samcrac XJ Cherokee Technical Forum 2 11-17-2004 03:21 PM
Door panel jgai11bb XJ Cherokee Technical Forum 3 09-24-2004 11:29 AM
Help with door panel????? 2ksportNY XJ Cherokee Technical Forum 15 04-23-2003 05:43 AM
