Door Panel Fasteners - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Door Panel Fasteners
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 10-10-2002, 04:02 PM   #1
thelonerangerr
real easy...
I replaced the speakers in the front doors of my 98, but you kinda have to break the little fasteners to get the panel off (well, I broke them. you don't really HAVE TO, I suppose).
where can I buy replacements besides the jeep dealerships? I called them and they want $4.50 a piece! Not for a set. For one. one little plastic clip.
besides ghettofying it from something found at Home Depot®, is there anything one of you has used in the past?
2003 Wrangler X, Freedom Edition
thelonerangerr is offline   Reply With Quote
Unread 10-10-2002, 04:14 PM   #2
EricsXJ
The Post man
EricsXJ's Avatar
Autozone should have them. Once I was browsing around and happened to see some. They had various kinds based on the make of the vehicle (GM, Ford, Chrysler, etc) I made a mental note, that if I ever need them, thats where to go. Take one in with you and you should be able to find the exact ones or something close that will work.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
